Zabbix 3.0.3 Server-Web-Mysql
  • support.zabbix@axelit.fr
    • Jul 2016
    I've installed Zb 3.0.3 on RHEL7
    Mariadb to another server with schema.sql
    Web frontend on a third one (RHEL7)
    Httpd : OK
    Zabbix-server :OK
    BDD connection : OK
    Connection to FrontEnd (user Admin) : OK
    Unfortunately, I'm unable to click on Adminitration/Configuration bouton - nothing appending.
    Dashboard not loading - see attachement
    No error messages in logs
    Where can I search ?
    Regards,
    Posh
  • MightBeAWizard
    • May 2016
    • 33
    Couple of things, are you blocking javascript for example?
    How about your SELinux on your servers?
      • Jul 2016
      MightbeaWizard,
      Thanks for your help. Problem sorted out.
      It was bad VPN configuration.
      Regards,
