Zabbix Reporting - unable to get it working
  • eebc-ict-netman
    • May 2022
    • 14
    I am having issue getting the reporting working with zabbix. I am quite new to zabbix but am not shy about getting under the hood.
    I have installed the following with out too much drama;
    web service
    chromium
    when I do test scheduled reports, I was getting the following error,
    annot fetch data: chrome failed to start:
    cmd_run.go:1046: WARNING: cannot create user data directory: cannot create "/var/lib/zabbix/snap/chromium/2590": mkdir /var/lib/zabbix/snap/chromium: permission denied
    Sorry, home directories outside of /home needs configuration.
    See https://forum.snapcraft.io/t/11209 for details.​
    I then tried to follow the direction on the snap website, and this is where I get really confused, and really don't understand what is required
    Home directories outside of '/home' | Snapcraft documentation​
    i am assuming that they are referring to the 'zabbix' user/service, but as this is a service it does not login and I do not have any credentials to login with except for zabbix being the username.
    also in the Snapcraft documentation they mention '$USER' - is this what I should type in the cli or should I put the username (zabbix), also should i log in as zabbix..... I usually take these as verbatim, but I am unabel to go any further.
  • xoxa
    • Sep 2023
    Same here
    • vijayk
      • May 2023
      • 305
      Please refer the link below. It will help you to bind the home directory.
      https://snapcraft.io/docs/home-outside-home
