Zabbix 6.0.20 anable HTTP authentication
  • mfuk
    • Jul 2023
    • 19
    Hi, I'm trying to enable HTTP authentication for my zabbix server 6.0.20.
    I have an EC2 instance running on AWS, and I configured ALB using Cognito authentication.
    I updated the files /etc/nginx/conf.d/zabbix.conf:
    server {
    listen 80 default_server;
    rewrite ^/?$ /index_http.php redirect;
    and /usr/share/zabbix/index_http.php:
    <?php
    require_once dirname(__FILE__).'/include/classes/user/CWebUser.php';
    require_once dirname(__FILE__).'/include/config.inc.php';
    $redirect_to = (new CUrl('index_http.php'))->setArgument('form', 'default');
    $request = getRequest('request', '');
    $test_request = [];
    preg_match('/^\/?(?<filename>[a-z0-9\_\.]+\.php)(\?.*)?$/i', $request, $test_request);
    if ($request !== '' && !CHtmlUrlValidator::validateSameSite($request)) {
    $request = '';
    if ($request !== '') {
    $redirect_to->setArgument('request', $request);
    if (CAuthenticationHelper::get(CAuthenticationHelper: :HTTP_AUTH_ENABLED) != ZBX_AUTH_HTTP_ENABLED) {
    redirect($redirect_to->toString());
    require_once dirname(__FILE__)."/include/oidc.inc.php";
    oidc();
    the file include/oidc.inc.php:​
    <?php
    $permitted_domains = [
    'mydomain.com',
    require_once dirname(__FILE__).'/classes/user/CWebUser.php';
    require_once dirname(__FILE__).'/config.inc.php';
    $test_request = [];
    function generateRandomString($length = 16) {
    return substr(str_shuffle(str_repeat($x='0123456789abcdef ghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ', ceil($length/strlen($x)) )),1,$length);
    function oidc() {
    global $permitted_domains;
    // Lets clear untrusted headers
    $_SERVER['PHP_AUTH_USER'] = '';
    $_SERVER['REMOTE_USER'] = '';
    $_SERVER['AUTH_USER'] = '';
    if ($_SERVER['HTTP_X_AMZN_OIDC_ACCESSTOKEN'] != '') {
    $parts = explode(".", $_SERVER['HTTP_X_AMZN_OIDC_ACCESSTOKEN']);
    $obj = json_decode(base64_decode($parts[1]), true);
    $roleid = 0;
    if ($obj['username'] != '') {
    $http_user = $_SERVER['PHP_AUTH_USER'] = strtolower($obj['username']);
    if (in_array('zabbix-admin', $obj['cognito:groups'])) {
    $roleid = 3;
    if (in_array("zabbix-read", $obj['cognito:groups'])) {
    $roleid = 1;
    if (!$http_user) {
    return;
    $parser = new CADNameAttributeParser(['strict' => true]);
    if ($parser->parse($http_user) === CParser::PARSE_SUCCESS) {
    if (!in_array($parser->getDomainName(), $permitted_domains)) {
    return;
    $uinfo = DBfetch(DBselect(
    'SELECT u.userid,u.attempt_failed,u.attempt_clock,u.attemp t_ip '.
    'FROM users u '.
    'WHERE u.username='.zbx_dbstr(strtolower($http_user))
    if(!$uinfo) {
    $name_surname = explode(".", $http_user);
    DB::insert('users',[[
    'username' => strtolower($http_user),
    'name' => strtolower($name_surname[0]),
    'surname' => strtolower($name_surname[1]),
    'passwd' => generateRandomString(), // unused, but have to set
    'autologin' => '1', // used to login by http
    'autologout' => '15m',
    'roleid' => $roleid,
    this code works fine, I can create the user in the mysql database.
    and enabled on Zabbix GUI HTTP authentication:
    when I try to connect to the servers, I login to the Cognito form but I receive this error:
    Could someone know how can fix it?
