Zabbix Server (composed) problem with DNS resolution
  • kingfisher77
    • Aug 2023
    Zabbix Notification: PostgreSQL database "zabbix" on "postgres:5432" is not available: could not translate host name "postgres" to address: Name does not resolve​
    This is what we get randomly (1-3 times per day) in a Docker setup. This messages comes as a notification and as an entry in the Zabbix Server log. Postgres is running. System log and docker environment is inconspicuous.
    Otherwise - the Zabbix server, the auto-registration, the templates, the active and passive elements, the triggers, the notifications, the graphical user interface - everything works fine.
    The VM size at Hetzner Cloud is comfortable (ccx13) for what we do with Zabbix (~20 Linux servers, some network devices).
    • Docker 24.0.5 (Ubuntu 22.4.3)
    • Zabbix 6.4
    • Postgres 14
    The docker-compose.yml is based on the official example.
    We run almost all of our services with Docker. The Zabbix setup is the first setup that has this error.
    Does anyone have any idea what can cause this error?
    PHP Code:
    services:
    postgres:
    hostname: postgres
        restart
    : always
    : postgres:14-alpine
        volumes
    postgres:/var/lib/postgresql/data
        env_file
    env_vars/.env_pgsql
        secrets
    POSTGRES_USER
    - POSTGRES_PASSWORD
        healthcheck
    test: ["CMD-SHELL", "pg_isready --dbname=$${POSTGRES_DB} --username=$${PGSQL_USER}"]
    interval: 60s
          timeout
    : 5s
          retries
    : 3
        stop_grace_period
    : 1m​
      server
    hostname: zabbix
    : zabbix/zabbix-server-pgsql:alpine-6.4-latest
        restart
    : always
        ports
    10051:10051
        env_file
    env_vars/.env_srv
    - ./env_vars/.env_pgsql
        secrets
    POSTGRES_USER
    - POSTGRES_PASSWORD
        volumes
    server-usr-lib:/usr/lib/zabbix
    - server-var-lib:/var/lib/zabbix
        depends_on
    postgres
    #ulimits:
        #  nproc: 65535
        #  nofile:
        #    soft: 20000
        #    hard: 40000
        #deploy:
        #  resources:
        #    limits:
        #      cpus: '0.70'
        #      memory: 1G
        #    reservations:
        #      cpus: '0.5'
        #      memory: 512M
    sysctls:
    net.ipv4.ip_local_port_range=1024 65000
    - net.ipv4.conf.all.accept_redirects=0
    - net.ipv4.conf.all.secure_redirects=0
    - net.ipv4.conf.all.send_redirects=0​
    volumes
    postgres:
    server-usr-lib:
    server-var-lib:
    ### Networks
    networks:
      default:
    enable_ipv6: true
        ipam
    driver: default
    config:
    subnet: fd00:5c32:de45::/80
              gateway
    : fd00:5c32:de45::1
      traefik
    external: true
    secrets
    POSTGRES_USER:
    file: ./env_vars/.POSTGRES_USER
      POSTGRES_PASSWORD
    file: ./env_vars/.POSTGRES_PASSWORD​
