Zabbix JMX Tomcat Heap Memory monitoring failure
  • jtarjanyi
    • Oct 2022
    I need to monitor remote tomcat server. I have successfully setup Java-gateway on zabbix server and configured JMX port on tomcat side. I have tested to connection from zabbix server to tomcat with jmxterm and able to fetch values.
    I have also added tomcat server as host with JMX interface and applied 'Appache Tomcat by JMX template. All items provided by the template work properly, but when I have tried to add HeapMemory usage as new item, it fails. If I try to test it I have got
    Object or attribute not found: “java.lang:type=Memory”
    my settings is:
    key: jmx[“java.lang:type=Memory”,”HeapMemoryUsage.used”]
    JMX Endpoint: service:jmx:rmi:///jndi/rmi://{HOST.CONN}:{HOST.PORT}/jmxrmi
    from jmxterm it fetch value:
    $>get -b java.lang:type=Memory HeapMemoryUsage.used
    #mbean = java.lang:type=Memory:
    HeapMemoryUsage.used = 414034592;​
    Any idea what may be wrong ?
  • Answer selected by jtarjanyi at 04-09-2023, 13:38.
    jtarjanyi
    • Oct 2022
    Addig Generic Java JMX fixed the issue. Not sure what was wrong when I wanted to add as individual Item.
    It is OK now, so don't stress myself too much what was wrong ​
    • jtarjanyi
      • Oct 2022
