Zabbix cant load image for branding frontend
  • RobinH
    • Jul 2023
    • 55
    Hey everybody!
    I am trying to rebrand our zabbix server according to the documentation available (https://www.zabbix.com/documentation...ace/rebranding) and
    I have created three images as per the specification given in .png file format. (114x31, 91x24, 24x24)
    If I test the path for the files, they are located correctly, but I only get an image file icon like Zabbix cannot find or load the files.
    Anyone experienced the same problem?​
    zafe@fw-fortigate-monitoring:~$ cd /home/zafe/Pictures
    zafe@fw-fortigate-monitoring:~/Pictures$ ls
    Here is my config (brand.conf.php)
    <?php
    return [
        'BRAND_LOGO' => '/home/zafe//Pictures/custom_logo.png',
        'BRAND_LOGO_SIDEBAR' => '/home/zafe/Pictures/custom_logo_sidebar.png',
        'BRAND_LOGO_SIDEBAR_COMPACT' => '/home/zafe/Pictures/custom_logo_sidebar_compact.png',
        'BRAND_FOOTER' => '© Zafe Care Systems',
        'BRAND_HELP_URL' => 'https://www.zafe.se/support'
    • 4996
    Can you access those files on command line when you switch to the user that runs your webserver? Better move those pics to a place, where web server user can see them....
    • RobinH
      • Jul 2023
      • 55
      Hmm I have tried both with root and zafe user. Is there a place i Zabbix directory where its easy to store them?
      • RobinH
        • Jul 2023
        • 55
        Now I have tried to place it in the zabbix directory, /usr/share/zabbix which should not be a problem to find the file.
        But it still doesnt load it.
        I have changed so I just use one image to test with for the login-screen, so it now looks like this:
        <?php
        return [
            'BRAND_LOGO' => '/usr/share/zabbix/custom_logo.png',
            'BRAND_FOOTER' => '© Zafe Care Systems AB'
        And if i look in the directory its there with everything els....
        root@fw-fortigate-monitoring:/usr/share/zabbix# ls
        api_jsonrpc.php     composer.json                hostinventories.php  jsLoader.php  templates.php
        api_scim.php        composer.lock                host_prototypes.php  jsrpc.php     toptriggers.php
        app                 conf                         httpconf.php         local         tr_events.php
        assets              custom_logo.png              httpdetails.php      locale        trigger_prototypes.php
        audio               data                         image.php            map.php       triggers.php
        browserwarning.php  disc_prototypes.php          imgstore.php         modules       vendor
        chart2.php          favicon.ico                  include              report2.php   widgets
        chart3.php          fonts                        index_http.php       report4.php   zabbix.php
        chart4.php          graphs.php                   index.php            robots.txt
        chart6.php          history.php                  index_sso.php        setup.php
        chart7.php          host_discovery.php           items.php            sysmap.php
        chart.php           hostinventoriesoverview.php  js                   sysmaps.php​
        • RobinH
          • Jul 2023
          • 55
          If I try a URL to our website where the logo-file also is located it works. (But the logo is to big). But with the same logo-file and located in the local directory it doesnt find it.
          Is something wrong with where I try to store them?​
            • 4996
            Note that the path to the image on the disk should be relative to the Zabbix frontend root directory
            'BRAND_LOGO' => './custom_logo.png',
            • RobinH
              • Jul 2023
              • 55
              Doesnt work when the .png file is located in the same folder as the conf-file.
              • solution
                • Jun 2020
                • 272
                use:
                1)
                2) Move 'custom_logo.png' TO /usr/share/zabbix/
                Wellington
                • nameuser
                  • Apr 2018
                  • 39
                  Same problem - Zabbix server doesn't use brand.conf.php.
                  Config: /usr/share/zabbix/brand.conf.php
                  <?php
                  return [
                  'BRAND_FOOTER' => 'Test footer copyright'
                  Zabbix 6.4.7.
                  Nothing changed - footer copyright is the same.
                  Also tried to put brand.conf.php in /usr/share/zabbix/conf/brand.conf.php.
                  Nothing changed - footer is the same.
                  • solution
                    • Jun 2020
                    • 272
                    In Debian 11, package installation path is:
                    /usr/share/zabbix/local/conf/brand.conf.php
                    Wellington
                    • nameuser
                      • Apr 2018
                      • 39
                      one two three
                      • ianiovski
                        • Nov 2024
                        Hello, I also want to change the logo of the site, but the link does not work:
                        Is there an alternate guide or has someone saved the page itself.
                        My version of Zabbix is 7.0
                          • 4996
                          • hermanekt
                            • Aug 2019
                            • 66
                            Hi i created topic with explanation how to do this via native way and don be in stress during update/upgrades for loosing any of this configuration https://www.initmax.com/wiki/customi...bbix-frontend/ rebranding included.
