Zabbix v6.4.6 -configure DB connection with postgreSQL errors out
  • Rizzyzam
    • Aug 2023
    Hello All,
    I am using certificate DB authentication to a remote postgreSQL DB v 13.11. The auth works fine using psql and zabbix server backend connects to the DB without any issues. However, when I try to configure DB on the frontend, it just says on "Error connecting to the database" no matter what i pass. I added the php config file manually to /usr/share/zabbix/zabbix.conf.php.
    update:
    I keep getting errors httpd log file( this has nothing to do with DB connections but it seems to be a bug on v6.4.6)
    [proxy_fcgi:error].. AH1071: Got error 'PHP message: PHP Warning: Trying to access array offset on value type null in /usr/share/zabbix/include/classes/core/CCookieSession.php on line 194'.
    it seems to be performing the client side validations but never sends the connections to the backend. I checked the cookie it seems to have all the details that i am passing.
    Could you please provide your suggestions and comments
    Version details
    RHEL9
    zabbix v 6.4.6
    ​​httpd - Apache 2.4.53​​​
    PHP 8.1.14​
  • Rizzyzam
    • Aug 2023
    Configured DB certificate authentication from php successfully. It was just a permission issue and i had to create a dedicated certificate directory with permission sets for httpd.
    Now both the frontend and backend are authenticating with postgreSQL DB using SSL certificates.
