Hi all,
So I'm new to setting up any kind of zabbix server, and I'm trying to configure a proxy server, but it will not start properly.
I'm running OpenSUSE 13.1
Here is the most recent attempt from the zabbix-proxy.log file:
Starting Zabbix Proxy (passive) [<server_name>]. Zabbix 2.2.14 (revision 61184).
**** Enabled features ****
SNMP monitoring: YES
IPMI monitoring: YES
WEB monitoring: YES
VMware monitoring: YES
ODBC: YES
SSH2 support: YES
IPv6 support: YES
using configuration file: /etc/zabbix/zabbix-proxy.conf
The proxy does not match Zabbix database. Current database version (mandatory/optional): 02040000/02040000. Required mandatory version: 02020000.
It seems like there is a version mismatch, but the current one is the higher one, so does something else need to be updated?
Thanks in advance!
WEB monitoring: YES
ODBC: YES
SSH2 support: YES
IPv6 support: YES
Thanks in advance!
