Zabbix 6 no longer supports sysUpTime oid
  • biotenshu
    • Sep 2023
    Greetings. Here is the situation.
    On zabbix 5.2.7​
    On zabbix 6.0.19
    snmp_parse_oid(): cannot parse OID "SNMPv2-MIB::sysUpTime.0".
    Two servers, first main, second for migration to version 6 tests. Same template, similar devices. Why such difference? Version 6 no longer supports sysUpTime oid?
  • Answer selected by biotenshu at 05-09-2023, 10:51.
    Hamardaban
    • May 2019
    • 2714
    It's not zabbix can't, but snmp. Check the snmpd settings files, the paths to the mib files, and the presence of the mib files themselves.
    • Hamardaban
      • May 2019
      • 2714
      • biotenshu
        • Sep 2023
        Yes, it was snmp and mibs. Prod server 5 was installed by ansible roles, so there were all the dependencies, and the new 6 server was installed manually and something was forgotten. Thank you!
