Zabbix Proxy unable to fetch data from zabbix passive agents
  • vishal3108
    • Aug 2023
    Zabbix Agents ( Passive) 6.0.4
    Zabbix Proxy (Active Mode)v6.0.4
    Zabbix Agent env-
    - env:
    - name: ZBX_HOSTNAME
    valueFrom:
    fieldRef:
    apiVersion: v1
    fieldPath: spec.nodeName
    - name: ZBX_PASSIVESERVERS
    value: x.x.x.x
    - name: ZBX_SOURCEIP
    value: 0.0.0.0
    - name: ZBX_SERVER_PORT
    value: "10051"
    - name: ZBX_DEBUGLEVEL
    value: "5"
    - name: ZBX_TIMEOUT
    value: "10"
    - name: ZBX_PASSIVE_ALLOW
    value: "true"
    - name: ZBX_ACTIVE_ALLOW
    value: "false"
    image: zabbix/zabbix-agent2:alpine-6.0.4
    Zabbix Proxy env-
    - env:
    - name: ZBX_PROXYMODE
    value: "0"
    value: 0.0.0.0
    value: abcd
    - name: ZBX_SERVER_HOST
    value: x.x.x.x:31011
    value: "5"
    - name: ZBX_CACHESIZE
    value: 256M
    - name: ZBX_JAVAGATEWAY_ENABLE
    value: "false"
    - name: ZBX_CONFIGFREQUENCY
    value: "60"
    - name: ZBX_VALUECACHESIZE
    value: 128M
    image: zabbix/zabbix-proxy-sqlite3:alpine-6.0.4
    We have multiple servers on which zabbix agents are running as kubernetes daemonsets
    Zabbix agents (running as kubernetes daemonsets pods) are running but unable to accept incoming connections from zabbix proxy pod.
    2023/08/29 05:58:51.784103 starting manager
    2023/08/29 05:58:51.784287 [0] starting listener for '0.0.0.0:10050'
    2023/08/29 05:58:51.787962 listening for control connections on /tmp/agent.sock
    2023/08/29 05:59:05.488563 cannot accept incoming connection for peer: x.x.x.x
    2023/08/29 05:59:10.465123 cannot accept incoming connection for peer: x.x.x.x
    Above error is reporting in zabbix agent logs and x.x.x.x is particular node IP on which respective agent pod is running.
    All agent pods are giving same errors.
    Zabbix agent and proxy are on same kubernetes cluster, still it is not accepting incoming connection.
    Please advise.
