False Icmppingloss in graph
  • bcl
    • Jun 2023
    Can somebody help me with following issue. It is on zabbix 6.4.1.
    've got an issue where that my icmploss graph shows loss
    But when i check it from the proxy it selves it doenst lose any packets at all.
    I even check the part where the graph shows loss, the manual fping command does not show any.
    Anybody got an idea on why this is?
    The setup is a proxy server is monitoring a wan ip address and the graph is on the main zabbix server.
  • ganyjar
    • Oct 2023
    I have the same problem as you, have you found a solution?
