Temporary MSSQL: Service is unavailable due to network delays
  • anslu
    • Aug 2023
    • 30
    we are using Zabbix to monitor MSSQL databases via ODBC. Everything works fine, but there's one problem related with distance between Zabbix host and one of monitored databases.
    There's a network delay varying from 230 to 300 ms between both and that's causing short-lasting notifications about MSSQL service unavailability. There should be Zabbix proxy closer to monitored DB, but since there's only one DB I would rather avoid setting up another host just for this DB.
    Is there a way to modify the MS SQL trigger somehow to add e.g. 1 minute of delay or something like that?
    MSSQL: Service is unavailable (1.png) Click image for larger version
    Will this trigger work once modified like this? (2.png) Click image for larger version
