Announcement
No announcement yet.
Zabbix-Agent restart no pid file...
  • Filter
    Hi All,
    I run a Zabbix server, i have several host running, they are shown "available" in mij "host list". But then some hosts give me the next message instead of available:
    Availability: "Not available"
    Error: "Cannot connect to [host10] [Connection refused]"
    Now when i logon to that machine and i try to restart the zabbix agent i get the following message:
    [email protected]:/# /etc/init.d/zabbix-agent restart
    Stopping Zabbix agent: zabbix_agentd
    No process in pidfile `/var/run/zabbix/agentd.pid' found running; none killed.
    Starting Zabbix agent: zabbix_agentd
    My zabbix-agent.conf file contains the following:
    ##-Configured
    # This is config file for zabbix_agentd
    # To get more information about ZABBIX, go http://www.zabbix.com
    # List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
    # No spaces allowed. First entry is used for sending active checks.
    # Note that hostnames must resolve hostname->IP address and
    # IP address->hostname.
    Server=172.17.6.217
    #172.17.6.217
    #172.17.6.217
    # Server port for sending active checks
    # ServerPort=10050
    # Unique hostname. Required for active checks.
    Hostname=host217
    # Listen port. Default is 10050
    # ListenPort=10050
    # IP address to bind agent
    # If missing, bind to all available IPs
    # ListenIP=172.17.6.217
    # Number of pre-forked instances of zabbix_agentd.
    # Default value is 5
    # This parameter must be between 1 and 16
    StartAgents=5
    # How often refresh list of active checks. 2 minutes by default.
    RefreshActiveChecks=10
    # Disable active checks. The agent will work in passive mode listening server.
    #DisableActive=1
    #EnableRemoteCommands=1
    # Specifies debug level
    # 0 - debug is not created
    # 1 - critical information
    # 2 - error information
    # 3 - warnings (default)
    # 4 - for debugging (produces lots of information)
    DebugLevel=3
    # Name of PID file
    PidFile=/var/run/zabbix/agentd.pid
    #/var/run/zabbix/agentd.pid
    #PidFile=/var/run/zabbix/agentd.pid
    #/var/tmp/zabbix_agentd.pid
    # Name of log file.
    # If not set, syslog will be used
    LogFile=/var/log/zabbix/agentd.log
    #/var/log/zabbix/agentd.log
    #/tmp/zabbix_agentd.log
    # Spend no more than Timeout seconds on processing
    # Must be between 1 and 30
    Timeout=30
    # Format: UserParameter=<key>,<shell command>
    # Note that shell command must not return empty string or EOL only
    #UserParameter=system.test,who|wc -l
    ### Set of parameter for monitoring MySQL server (v3.23.42 and later)
    ### Change -u<username> and add -p<password> if required
    #UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
    #UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
    #UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"$
    #UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -$
    #UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1$
    #UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
    #UserParameter=mysql.version,mysql -V
    #UserParameter=iptb_out[*],iptc_getrule filter from_us "$1" b
    #UserParameter=iptp_out[*],iptc_getrule filter from_us "$1" p
    #UserParameter=iptb_in[*],iptc_getrule filter to_us "$1" b
    #UserParameter=iptp_in[*],iptc_getrule filter to_us "$1" p
    If you need more information please let me know?
    My OS is debian...
    Grz Robbert
    check if you have the directory '/var/run/zabbix/' and '/var/log/zabbix'
    check the permissions of both directories.
    I guess, the owner must be user 'zabbix' and group 'root' with 750 permissions.
    I hope this help.
      Hey...
      this are my settings...
      [email protected]:/var/run/zabbix# ls -l
      total 4
      -rwxrwxrwx 1 root root 5 2006-11-21 14:52 zabbix_agentd.pid
      [email protected]:/var/log/zabbix# ls -l
      total 0
      -rwxrwxrwx 1 root root 0 2006-11-20 09:51 agentd.log
      -rwxrwxrwx 1 root root 0 2006-11-21 12:19 agent.log
      [email protected]:/var/run/zabbix# /etc/init.d/zabbix-agent restart
      grz Robbert
        Originally posted by MrRobbert
        Hey...
        total 4
        send 'ls -la' this include information of current directory.
        if the user zabbix don't have permission to entry into /var/run/zabbix
        777 in zabbix_agentd.pid, don't have effect.
        grz Robbert
        owww, you tring to 'restart' a process with maybe not running at moment.
        try
        # /etc/init.d/zabbix-agent start
        # ps fax | grep zabbix
        if have process don't have troble.
        if do not.
        # tail /var/log/zabbix/agentd.log
        and see the error.
          Hey, oke i tried it, but didnt work...
          [email protected]:~# /etc/init.d/zabbix-agent start
          [email protected]:~# ps fax | grep zabbix
          5482 pts/1 S+ 0:00 \_ grep zabbix
          [email protected]:~# tail /var/log/zabbix/agentd.log
          [email protected]:~# /etc/init.d/zabbix-agent stop
          my server still wont connect to monitor this host...
          Grz Robbert
            I guess you are tring to run zabbix version 1.1.4, ok?
            and if you run, just:
            # ./zabbix_agentd -c <config_file>
              i dont know what i did, but i just restarted the server and suddenly it started to monitor that perticular server... i did everything here in this topic... i'll hope its stays monitored now...
              anyway everyone tnx for youre help...
                Oke now its very strange, but now again i get the same message and my zabbix server doesnt reconnect again... Anybody knows what i can do about this?
                  can you post a ls -al of the directories /var/run/zabbix and /var/log/zabbix ?
                  on your first post, in the config file, you have
                  but in your ls, it shows
                  /var/run/zabbix/zabbix_agentd.pid
                  not quite the same ...
                    Hi it is...
                    total 0
                    --- and
                    total 0
                    -rwxrwxrwx 1 root root 0 2006-11-27 09:41 agentd.pid
                    --- and
                    --- Log files are empty...
                    Grz Robbert
                      ok i saw that, but ps -l is not ps -al
                        ow yeah srry
                        [email protected]:/var/log/zabbix# ps -al
                        F S UID PID PPID C PRI NI ADDR SZ WCHAN TTY TIME CMD
                        4 S 0 7203 3827 0 76 0 - 1009 - tty1 00:00:00 bash
                        0 R 0 22883 22588 0 76 0 - 550 - pts/1 00:00:00 ps
                        [email protected]:/var/run/zabbix# ps -al
                        0 R 0 22893 22588 0 75 0 - 550 - pts/1 00:00:00 ps
                        Grz Robbert
                          my bad it's ls -al not ps
                            lol
                            [email protected]:/var/run/zabbix# ls -al
                            total 0
                            drwxr-xr-x 2 root root 60 2006-11-27 09:41 .
                            drwxr-xr-x 8 root root 540 2006-11-27 09:40 ..
                            [email protected]:/var/run/zabbix# ls -al /var/log/zabbix/
                            total 8
                            drwxrwx--- 2 zabbix adm 4096 2006-11-21 12:19 .
                            drwxr-xr-x 7 root root 4096 2006-11-27 06:25 ..
                              ok
                              the owner of the /var/run/zabbix dir is root, and write acces is only set for root,
                              what i do is set zabbix as owner and don't change the rights, they are good.
                              assuming a user zabbix exists,
                              just make a
                              chown zabbix /var/run/zabbix/
                              and
                              chown zabbix /var/run/zabbix/*
                              to be fully correct, also run :
                              chmod 664 /var/run/zabbix/*
                              and for the log dir :
                              chmod 755 /var/log/zabbix/
                              chown zabbix /var/log/zabbix/*
                              chmod 664 /var/log/zabbix/*
                              I think that will make it
                              repost ls -al after modifications, just to be sure
