Pushover notification fails because 'field "message" cannot be empty'
  • mlazzarotto
    • Feb 2022
    • 14
    I've just configured Pushover to send notification on Zabbix 6.4.5, but it's not working because it says Pushover notification failed: field "message" cannot be empty.
    I have 1 trigger action to send me both a email and a pushover message.
    I don't believe that the 'message' field is empty because the email works well.
    To configure Pushover on Zabbix I used the default parameters when creating the "Media type", except for the API token.
    Click image for larger version  Name:	image.png Views:	0 Size:	46.1 KB ID:	470940​
    The "message template" has the default fields
    Click image for larger version  Name:	image.png Views:	0 Size:	15.6 KB ID:	470941​
  • mlazzarotto
    • Feb 2022
    • 14
    Nevermind, the firewall was blocking connections to api.pushover.net.
