Truenas SCALE OID changed in release 22.12.1 - zabbix monitoring template not working
  • triplus
    • Sep 2023
    Hi
    After upgrading truenas SCALE from 22.12.0 to 22.12.3.3 I realized my zabbix (zabbix V6.0) monitoring completely broke for truenas. Upon checking the OIDs via an SNMP walk, I realized the locations of important data has moved to different OIDs.
    Some values are still being "read", but datasets are suddenly reporting as 119% full in monitoring ect. (which obviously isn't the case when looking via truenas).
    I found https://ixsystems.atlassian.net/browse/NAS-120434 which states indeed that "in 22.12.1 snmp and so OID names and things have changed. ".
    I just want to check if anyone else ran into the same issue recently? Since - I assume - SNMP monitoring would still work for truenas CORE, I want to check if there is anything to do to get monitoring working (again) for truenas SCALE.
    Since it's a bit of a grey area (was it luck that CORE monitoring template worked for SCALE and is this a feature request to add a new template for SCALE specifically, or is this​ a bug since it stopped working and was working before...), I want to get a bit of insight from the community on this.
    Thanks!
  • Jason_O
    • Jan 2024
    I am getting the three following "average" severity
    1. TrueNAS: Pool [boot-pool]: Status is not online
    2. TrueNAS: Pool [TrueNas-Backup]: Status is not online
    3. TrueNAS: Pool [Nas-Main]: Status is not online​
    TrueNAS-SCALE-23.10.1.1 & Zabbix 6.4
    • triplus
      • Sep 2023
      Hi - I had created this: https://github.com/tr1plus/zabbix_truenas_SCALE_snmp to try to get around the issue. Maybe not as perfect as the original one, but it works for my purposes
      • markfree
        • Apr 2019
        • 875
        I must say that this is still a valid template for TrueNAS Community (Scale) 25.04, while using Zabbix 7.2
        I only had to adjust the "L2ARC" and "ZIL" items and update the SNMP items to the newer format.
        Thanks!
        • triplus
          • Sep 2023
          Hi - great to see this is still being used .
          I recently updated some things for ARC
          If you are willing - feel free to make a pull request or share the 7.2 version in the same repo. Might be helpful to others.
          Kind regards
