Can´t add permissions to host group on user groups
  • userno
    • Sep 2023
    • 19
    Hi, i'm using zabbix server 6.0.21 and i'm trying to make a users group with permissions of read of the linux servers. I add the rule and update but when i enter once again on the users group this don't have any permissions.
    I enter on the permissions tab of the group , it's empty.
Name:	Captura desde 2023-09-25 14-13-23.png
    I added the permissions and later click on update. Appears a green message indicated that the configuration it's okey and saved.
Name:	Captura desde 2023-09-25 14-13-48.png
    I enter once again and it's still empty.
Name:	Captura desde 2023-09-25 14-14-12.png
  • tim.mooney
    • Dec 2012
    • 1437
    After the 2nd screenshot, before you click the "Update" button, did you click "Add"?
    • userno
      userno commented
      After i selected the host group i click on add but it disappears.
    • 5004
    That little "Add" should use blink tags.. Or some popup after "update" that asks, if you Add-ed things...and takes you back if you say NO...
    • userno
      userno commented
