Is it possible to send a "missing data" value for a trapper item?
  • michaill
    • May 2014
    • 18
    I have a trapper item that calculates a statistic (int) about some local resource.
    When the resource is not available, I'd like to send a "missing data" value for the item as an indication that the resource is down. However I cant figure out how to do that. If an empty string is sent, then it shows up in zabbix as an empty string, not missing data.
    Any suggestions are welcome. If anything is unclear, I can elaborate more.
    Mike
  • LenR
    • Sep 2009
    • 1011
    Typically, 0 is "service not running", but if 0 is already valid, try -1. I think I did that by accident once, but I don't remember if an int item was disabled or if the sender got a bad return code. You might be able to change the item to float, then test for less than 0 as unavailable.
