App MS SQL Instance Discovery return error
  • studero
    • Aug 2023
    • 85
    My Zabbix server run on RedHat 9 with the last version of Zabbix.
    I want to monitor MS-SQL Server with multi instance. I have tried to use the community-templates/Databases/Microsoft_SQL_Server/template_app_ms_sql_instance_discovery_(lld)/6.0 at main · zabbix/community-templates (github.com)​
    But I have a problem when run the Discover rules. I have the following error message "Unsupported item key" with the Key "windowssqlinstances.discovery"
    From my Zabbix server, I run the following command with the same result:
    [root@svx-mon-02t ~]# zabbix_get -s svw-mssql-01t -k windowssqlinstances.discovery
    ZBX_NOTSUPPORTED: Unsupported item key.
    [root@svx-mon-02t ~]#​
    I thinks that I need or there are an error into the Template.
    Thanks for your help
    Regards
    Olivier​
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    FYI The thread actually started here:
    As an alternative, you can use the official template for MS SQL monitoring, using ODBC:
    • studero
      studero commented
      Ok, Now I have testing using ODBC. But that's does not work. I have the following error:
      Cannot connect to ODBC DSN: [SQL_ERROR]:[HY000][458752][[unixODBC][Microsoft][ODBC Driver 18 for SQL Server]SSPI Provider: No credentials were supplied, or the credentials were unavai]|[HY000][458752][[unixODBC][Microsoft][ODBC Driver 18 for SQL Server]Cannot generate SSPI context]
      I have some questions about the configiguration of ODBC:
      - odbc.ini file contains the following information. It is true ?
      # cat odbc.ini
      [svw-mssql-01t]
      Driver = ODBC Driver 18 for SQL Server
      Server = svw-mssql-01t,1431
      Database = GESTENS
      Encrypt = No
      Trusted_Connection = Yes
      - Wich type of use I need to connect to the Database ? Actually I use an Account AD user ?
      Regards
      Olivier
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Could this one be of any help? https://www.zabbix.com/forum/zabbix-...-a-domain-user
    • studero
      studero commented
      Hi dimir
      I'm able to create a connection from the Linux server to the MS-SQL server using the following commande and result:
      ]# isql -v svw-mssql-01t USER PASSWORD
      | Connected!                            |
      | sql-statement                         |
      | help [tablename]                      |
      | echo [string]                         |
      | quit                                  |
      SQL>
      But not with the sqlcmd commande as follow :
      # sqlcmd -S svw-mssl-01t\\GESTENS -C -E
      Sqlcmd: Error: Microsoft ODBC Driver 18 for SQL Server : Login timeout expired.
      Sqlcmd: Error: Microsoft ODBC Driver 18 for SQL Server : SQL Server Network Interfaces: Error Locating Server/Instance Specified [xFFFFFFFF]. .
      Sqlcmd: Error: Microsoft ODBC Driver 18 for SQL Server : A network-related or instance-specific error has occurred while establishing a connection to svw-mssl-01t\GESTENS. Server is not found or not accessible. Check if instance name is correct and if SQL Server is configured to allow remote connections. For more information see SQL Server Books Online..
      I need more help
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Sorry, I have never set up MS SQL monitoring, hopefully someone else could help here.
    • vijayk
      • May 2023
      • 305
      Have you installed the ODBC driver in Zabbix server?
      • dimir
        Zabbix developer
        • Apr 2011
        • 1080
        FYI. The work has started on Agent 2 plugin for MS SQL monitoring without ODBC, planned for 7.0: https://support.zabbix.com/browse/ZBXNEXT-6235
