Zabbix Proxy 7alpha4 will not run on a Raspberry PI on 11 (bullseye)
  • mellis
    • Oct 2017
    • 145
    I did an upgrade on a server and one proxy, the server runs no issue but the proxy will not start. Both of these systems are PI 4 with 8gb ram for the server and 4gb ram on the proxy.
    On the proxy I am not getting the logging to start I am getting a message in the journal I see this error:
    pi@proxy1:/etc/zabbix $ journalctl -xe
    -- Support: https://www.debian.org/support
    -- The unit zabbix-proxy.service has entered the 'failed' state with result 'signal'.
    Sep 30 09:22:18 proxy1.thewayiseeit.net systemd[1]: Failed to start Zabbix Proxy.
    -- Subject: A start job for unit zabbix-proxy.service has failed
    -- Defined-By: systemd
    -- A start job for unit zabbix-proxy.service has finished with a failure.
    -- The job identifier is 4378 and the job result is failed.
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: zabbix-proxy.service: Scheduled restart job, restart counter is at 47.
    -- Subject: Automatic restarting of a unit has been scheduled
    -- Automatic restarting of the unit zabbix-proxy.service has been scheduled, as the result for
    -- the configured Restart= setting for the unit.
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: Stopped Zabbix Proxy.
    -- Subject: A stop job for unit zabbix-proxy.service has finished
    -- A stop job for unit zabbix-proxy.service has finished.
    -- The job identifier is 4443 and the job result is done.
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: Starting Zabbix Proxy...
    -- Subject: A start job for unit zabbix-proxy.service has begun execution
    -- A start job for unit zabbix-proxy.service has begun execution.
    -- The job identifier is 4443.
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: zabbix-proxy.service: Control process exited, code=killed, status=11/SEGV
    -- Subject: Unit process exited
    -- An ExecStart= process belonging to unit zabbix-proxy.service has exited.
    -- The process' exit code is 'killed' and its exit status is 11.
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: zabbix-proxy.service: Failed with result 'signal'.
    -- Subject: Unit failed
    Sep 30 09:22:28 proxy1.thewayiseeit.net systemd[1]: Failed to start Zabbix Proxy.
    -- The job identifier is 4443 and the job result is failed.
    I have dropped the database and recreated it.
    These were running zabbix 6.4 till the upgrade with no issues.
