Zabbix 6.4.4 Discovery Rule Issue
  • MohamedHaseeb
    • Oct 2023
    I need your support as I have an issue in the discovery rule in Zabbix. I created Zabbix Discovery Rule to discover the IP range "172.31.0.0/16" and to check "Zabbix agent "system.hostname"" and the frequency is 1 m
    We already Installed Agent on "172.31.37.109" and the value of "system.hostname" in the agent is
    zabbix_agentd -t "system.hostname"
    system.hostname [s|ip-172-31-37-109]
    the discovery status in the Discovery under the monitoring is empty and nothing discovered.
    Best Regards,
    Mohamed Haseeb
  • Hamardaban
    • May 2019
    • 2714
    Checking the network /16 range is a long process, which primarily depends on the polling timeout.
    The period of 1 minute set by you is the period when the next "session" will start working after the current one ends.
    • MohamedHaseeb
      • Oct 2023
      Thank you for your support.
      I found that the server has been discovered but after more than 4 hours.
      I tried to create to another rule, and I added in the IP range new IP for new server 172.31.37.109. However, it has been discovered so far "10 minutes."
      • MohamedHaseeb
        • Oct 2023
        Meanwhile I found the below process running in Zabbix server
        zabbix 958 822 0 06:02 ? 00:00:00 /usr/sbin/zabbix_server: discoverer #1 [processed 0 rules in 0.000027 sec, performing discovery]
