zabbix server is not running after upgrading ubuntu from 18.04 to 20.04
  • ketrelzhang
    • Oct 2023
    I was running Zabbix 5.4.12 on Ubuntu 18.04 with MYSQL 5.7
    Last night I upgraded Ubuntu to 20.04, then my Zabbix stopped working.
    I noticed that MYSQL was upgraded to 8.0 automatically, but I checked it is running.
    I checked the log under /var/log/zabbix/zabbix_server.log.
    It kept saying below:
    [Z3001] connection to database 'zabbix' failed: [2002] Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
    also
    failed to accept an incoming connection: connection rejected, getpeername() failed: [107] Transport endpoint is not connected
    Can't figure out, could anyone help?
    Thanks.​
  • tim.mooney
    • Dec 2012
    • 1435
    Is it possible AppArmor or some other techology (SELinux) is blocking access to the socket?
    Have you verified that the path "/var/run/mysqld/mysqld.sock" is the actual path that MySQL has created for its local socket?
    Is there a mysql log file, maybe /var/log/mysqld.log or /var/log/mysql/error.log or similar that might have a clue?
    • ketrelzhang
      • Oct 2023
      HI Tim,
      Thanks for the information, I have checked mysql logs, it is fine. I am not too sure how to check if SELinux blocked the access to the socket?
      Could you please give me some advise?
      Thanks.
      • tim.mooney
        • Dec 2012
        • 1435
        Ubuntu, especially older Ubuntu, strongly prefers AppArmor, so it's more likely that AppArmor is enabled than SELinux. https://ubuntu.com/server/docs/security-apparmor
