Error with monitoring MongoDB with agent2
  • studero
    • Aug 2023
    • 85
    Hi all,
    I have configured my MongoDB with authentification mode.
    Like as:
    db.createUser(
    user: "zbx-mongo",
    pwd: "passwd",
    roles: [ { role: "root", db: "admin" } ]
    Now, I have some error with some metrics, like "MongoDB node by Zabbix agent 2: MongoDB: Get server status: MongoDB: Memory: mapped : Memory" or "MongoDB node by Zabbix agent 2: MongoDB: Get server status: MongoDB: Memory: mapped with journal zz0.oyqzj9bgs3pzz : mapped" or "WiredTiger metrics: MongoDB: Get server status: MongoDB: WiredTiger cache: max page size at eviction​" with the following errors:
    - mongodb.mem.mapped_with_journal" became not supported: Cannot fetch data: (Unauthorized) command serverStatus requires authentication
    - Cannot fetch data: (Unauthorized) command serverStatus requires authentication.
    The variables macros {$MONGODB.PASSWORD} and {$MONGODB.USER} are setting.
    I need help​
  • Baileykemp
    • Sep 2023
    You can ensure that the credentials you provided in the Zabbix configuration match the ones you set for the "zbx-mongo" user in MongoDB. Double-check the username and password for any typos or inconsistencies. If the credentials are correct, verify that the user has the necessary privileges to execute the "serverStatus" command and access the metrics you are trying to fetch. You can check the user's roles and permissions in MongoDB to ensure they have the appropriate access. UTSA Blackboard​
    • studero
      • Aug 2023
      • 85
      The "zbx-mongo" user has the rool "root". So I think that is correct ?
      I need some help to execute the "serverStatus" command to made the verification ?
      • studero
        • Aug 2023
        • 85
        Hi again,
        I have found some informations about the command "serverStatus". I share you my output. I think that's work correctly.
        See attached file​
        • studero
          • Aug 2023
          • 85
          Yesterday, I have remove the template MongoDB and his data. Then I have reapply the template with success. And the strange think is that they are no more error with the user/password.
          I have only one item with an error. This is "WiredTiger metrics: MongoDB: Get server status: MongoDB: WiredTiger cache: max page size at eviction" with the error "Preprocessing failed for: {"activeIndexBuilds":{"phases":{"commit":0,"dra inS ideWritesTable":0,"drainSideWritesTableOnCommit...
          1. Failed: cannot extract value from json by path "$.wiredTiger.cache['maximum page size at eviction']": no data matches the specified path"
          Do you have an idea ?​
            • 4996
            This means, that seemingly there is no such path in that json.. Either source does not show anything like it, or there is some minor mistake somewhere, like some capitalization error or something... You should try to obtain a full set of data that your main item is pulling and see, if it is there or what should be modified.
            • studero
              • Aug 2023
              • 85
              Hi cyber,
              I need help to test manualy this check ?
