HTTP proxy on web monitoring
  • akbar415
    • May 2015
    • 119
    Always I try to monitor a web site through my squid proxy I receive response code 407.
    Http proxy in my zabbix web scenario is
    HTML Code:
    http://user.squid:[email protected]:3128
    If I login in windows with this same user (user.squid) I can access the site.
    Checking zabbix doc I found that is used curl to make web monitoring.
    If a execute the follow in zabbix server I can check the web site with sucess
    curl -x http://user.squid:[email protected]:3128 --proxy-ntlm -L "www.google.com"
    So i tried to configure login and password in WEb Scenario HTTP Authentication = NTLM but whitout sucess ().
    There is some way to tell Zabbix to use proxy-ntlm authentication ?
  • richlv
    • Oct 2005
    • 3112
    i believe that's not supported at this time. you might want to create a new feature request at https://support.zabbix.com/browse/ZBXNEXT
    • akbar415
      • May 2015
      • 119
      No NTLM Proxy
      You are alright @richlv. Zabbix (even 3.0 version) don't support proxy basic authentication. This is weird because zabbix web scenario is based on libcurl and libcurl can be used with NTLM.
