Guest user
  • studero
    • Aug 2023
    • 85
    Guest user
    Hi all,
    After enable the guest user, I test in on my Zabbix web server to know what it can access. In my case, it can access to nothing.
    Why ?
    • 5004
    Did you check from user config, what kind of permissions have been added to guest user? Might aswell be "none"..
    • studero
      • Aug 2023
      • 85
      Yes, it is set at none. Thanks for your help
