AWS RDS Monitor in Zabbix
  • Preetham
    • Aug 2023
    Hi Team,
    Zabbix server is running on 6.4 ver and i created the user and access keys and imported the the RDS script on RDS Host templete and added the RDS instanace still its not collecting the logs.
    gettig below error
    Preprocessing failed for: {"error":"Required param is not set: "db_instance_id"."}
    1. Failed: cannot extract value from json by path "$..InstanceCreateTime.first()": no data matches the specified path
    1. Failed: TypeError: undefined not callable (property 'forEach' of [object Object])
    at [anon] (duktape.c:69012) internal
    at [anon] (function:2) preventsyield​
    Could you please help​
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    Did you follow these instructions: https://www.zabbix.com/integrations/aws_rds ?
    Especially
    Set macros "{$AWS.AUTH_TYPE}", "{$AWS.REGION}", "{$AWS.RDS.INSTANCE.ID}"
    • Preetham
      • Aug 2023
      Yes i followed the same document and configrued the AWS RDS, and seleted role based and in aws i have configured the role and assigned to ec2 where zabbix is running.
      Please help
      • Preetham
        • Aug 2023
        I used AWS by HTTP​ temlete and enable only RDS one and all RDS Server discovered by unabel to get the metric data getting error as AWS RDS: Failed to get events data​ what coudl be the reason. Can you please help
        and in Script its not mention anything on Role based auth. i used access & Secrete key
        • Preetham
          • Aug 2023
          screenshot​
          • Preetham
            • Aug 2023
            Hi Team,. Can some one help me why i get this error. i am able to discovery all AWS RDS Instanace details but unable to fetch the data.
