Zabbix Server Crashing every 7 days or so with same error
  • greentaco
    • May 2023
    Every 5-7 days or so my Zabbix Server 6.2.7 Running on Ubuntu 20.04 using Aurora RDS crashes with the same error, pasted below. I cannot even restart the Zabbix Server process, I have to forcefully reboot the EC2 instance to recover - I have no idea why this is happening but it seems to be fairly consistently every 5-7 days, I haven't been able to peg down any corollaries....Any guidance would be super duper helpful!
    13534:20231010:083149.667 slow query: 3.148626 sec, "begin;"
    13515:20231010:083154.439 slow query: 6.648752 sec, "select ip.itemid,ip.step,ip.type,ip.params,ip.error_handl er,ip.error_handler_params from item_preproc ip,item_discovery id where ip.itemid=id.itemid and id.parent_itemid=183705"
    13542:20231010:083155.076 slow query: 4.471124 sec, "select escalationid,actionid,triggerid,eventid,r_eventid, nextcheck,esc_step,status,itemid,acknowledgeid,ser vicealarmid,serviceid from escalations where triggerid is not null and mod(triggerid,5)=0 and nextcheck<=1696926713 order by actionid,triggerid,itemid,r_eventid asc,escalationid"
    13543:20231010:083155.312 slow query: 4.481551 sec, "select escalationid,actionid,triggerid,eventid,r_eventid, nextcheck,esc_step,status,itemid,acknowledgeid,ser vicealarmid,serviceid from escalations where triggerid is not null and mod(triggerid,5)=1 and nextcheck<=1696926713 order by actionid,triggerid,itemid,r_eventid asc,escalationid"
    14140:20231010:083156.689 slow query: 3.049810 sec, "select t.taskid,t.type,t.clock,t.ttl,c.command_type,c.exe cute_on,c.port,c.authtype,c.username,c.password,c. publickey,c.privatekey,c.command,c.alertid,c.paren t_taskid,c.hostid,cn.itemid,d.data,d.parent_taskid ,d.type from task t left join task_remote_command c on t.taskid=c.taskid left join task_check_now cn on t.taskid=cn.taskid left join task_data d on t.taskid=d.taskid where t.status=1 and t.proxy_hostid=14237 and (t.ttl=0 or t.clock+t.ttl>1696926713) order by t.taskid"
    13499:20231010:083157.476 slow query: 3.528084 sec, "begin;"
    14211:20231010:083157.521 failed to accept an incoming connection: from -------- : unspecified certificate verification error: TLS handshake set result code to 5:
    13535:20231010:083158.886 slow query: 5.219143 sec, "begin;"
    13524:20231010:083158.895 slow query: 4.498533 sec, "commit;"
    13546:20231010:083159.251 slow query: 5.569650 sec, "select escalationid,actionid,triggerid,eventid,r_eventid, nextcheck,esc_step,status,itemid,acknowledgeid,ser vicealarmid,serviceid from escalations where triggerid is not null and mod(triggerid,5)=4 and nextcheck<=1696926716 order by actionid,triggerid,itemid,r_eventid asc,escalationid"
    13534:20231010:083159.762 slow query: 4.433611 sec, "begin;"
    14119:20231010:083202.509 slow query: 19.266609 sec, "select t.itemid,t.type,t.snmp_oid,t.hostid,t.key_,t.delay ,t.history,t.status,t.value_type,t.trapper_hosts,t .logtimefmt,t.params,t.ipmi_sensor,t.authtype,t.us ername,t.password,t.publickey,t.privatekey,t.flags ,t.interfaceid,t.inventory_link,t.jmx_endpoint,t.m aster_itemid,t.timeout,t.url,t.query_fields,t.post s,t.status_codes,t.follow_redirects,t.post_type,t. http_proxy,t.headers,t.retrieve_mode,t.request_met hod,t.output_format,t.ssl_cert_file,t.ssl_key_file ,t.ssl_key_password,t.verify_peer,t.verify_host,t. allow_traps from items t,hosts r where t.hostid=r.hostid and r.proxy_hostid=10560 and r.status in (0,1) and t.flags<>2 and t.type in (0,7,20,12,2,3,9,10,11,13,14,16,17,5,19,18,21) order by t.itemid"
    13498:20231010:083202.512 One child process died (PID:13501,exitcode/signal:9). Exiting ...
    13676:20231010:083202.555 slow query: 3.356094 sec, "select t.taskid,t.type,t.clock,t.ttl,c.command_type,c.exe cute_on,c.port,c.authtype,c.username,c.password,c. publickey,c.privatekey,c.command,c.alertid,c.paren t_taskid,c.hostid,cn.itemid,d.data,d.parent_taskid ,d.type from task t left join task_remote_command c on t.taskid=c.taskid left join task_check_now cn on t.taskid=cn.taskid left join task_data d on t.taskid=d.taskid where t.status=1 and t.proxy_hostid=10560 and (t.ttl=0 or t.clock+t.ttl>1696926719) order by t.taskid"
    13523:20231010:083202.559 slow query: 3.670100 sec, "begin;"
    13928:20231010:083202.596 failed to accept an incoming connection: from ------------ : SSL_accept() timed out
    13545:20231010:083202.599 slow query: 3.146755 sec, "select escalationid,actionid,triggerid,eventid,r_eventid, nextcheck,esc_step,status,itemid,acknowledgeid,ser vicealarmid,serviceid from escalations where triggerid is not null and mod(triggerid,5)=3 and nextcheck<=1696926722 order by actionid,triggerid,itemid,r_eventid asc,escalationid"
    13543:20231010:083202.713 slow query: 4.892580 sec, "select escalationid,actionid,triggerid,eventid,r_eventid, nextcheck,esc_step,status,itemid,acknowledgeid,ser vicealarmid,serviceid from escalations where triggerid is null and itemid is not null and mod(itemid,5)=1 and nextcheck<=1696926720 order by actionid,triggerid,itemid,r_eventid asc,escalationid"
    14154:20231010:083202.749 failed to accept an incoming connection: from ----------- : SSL_accept() timed out
    13498:20231010:083202.952 PROCESS EXIT: 13501
    13499:20231010:083202.952 HA manager has been paused
    zabbix_server [13498]: Error waiting for process with PID 13501: [10] No child processes
    WARNING: MYSQL_OPT_RECONNECT is deprecated and will be removed in a future version.
    13498:20231010:083204.486 syncing history data...
    13498:20231010:083204.497 [Z3008] query failed due to primary key constraint: [1062] Duplicate entry '3003336-1696926707-415114176' for key 'history.PRIMARY'
    13498:20231010:083204.537 skipped 932 duplicates
    13498:20231010:083305.009 cannot connect to service manager service: Cannot connect to service "service": [111] Connection refused.
  • tim.mooney
    • Dec 2012
    • 1436
    You're running a version that is no longer supported and the 6.2 series is no longer getting updates. There were two additional patch releases (6.2.8, 6.2.9) released in early 2023, before the series went into unsupported status. You may want to try updating to 6.2.9, to see if that fixes the problem. The release notes for 6.2.8 and 6.2.9 each mention fixes for server crashes, but it's not possible to tell if they fix your specific crash.
    Longer term, your best option is to migrate to the 6.4.x series while it is still supported (not for much longer). Once the 7.0.x long term support (LTS) release has been out for a few weeks and appears stable, migrate to that.
    Being on a supported release series is the only way to get have an upgrade path when problems appear with the version you are running.
