Exclude mountpoint from mounted FS discovery
  • muelli
    • Jun 2021
    • 69
    Hello forum,
    my original problem solved itself, so I can elaborate on why I wanted to to exclude a single mountpoint from discovery.
    I want to lower the severity for one auto discovered mountpoint.
    My idea was: remove that single mountpoint from the template that auto discovers this, create a new template and make it discover that mountpoint, create items and triggers with lower severity.
    However I have stumbled upon a problem here, Since I wanted to use the vfs.fs.get key for this, I cannot attach the template to other hosts already using this key.
    Can this be solved somehow without manually lowering severity on host level?
    • 5004
    You can add an override to discovery.
    you can work around the issue of keys being already used with the help of aliases..
    Example 3 there is exactly, what you may need.
    • muelli
      • Jun 2021
      • 69
      thanks, that could just be what I am looking for!!!!
