Incomplete SNMP Graphs
  • ptera
    • Oct 2014
    • 109
    Zabbix 3.0.3. © 2001–2016, Zabbix SIA
    Number of hosts (enabled/disabled/templates) 288 250 / 0 / 38
    Number of items (enabled/disabled/not supported) 12703 4592 / 7883 / 228
    Number of triggers (enabled/disabled [problem/ok]) 343 343 / 0 [1 / 342]
    Number of users (online) 3 2
    Required server performance, new values per second 68.81
    Can anyone help?
    I do not have this problem with my version 2.4.5
    Number of hosts (enabled/disabled/templates) 983 917 / 11 / 55
    Number of items (enabled/disabled/not supported) 10743 8771 / 1668 / 304
    Number of triggers (enabled/disabled [problem/ok]) 3531 3524 / 7 [2 / 3522]
    Number of users (online) 8 3
    Required server performance, new values per second 146.68 -
    My server log on the 3.0 system is full of these.
    1623:20160817:094540.850 SNMP agent item "ifOperStatus[wifi0]" on host ".47 Ptera138" failed: first network error, wait for 15 seconds
    1652:20160817:094555.402 resuming SNMP agent checks on host ".47 Ptera138": connection restored
    1633:20160817:094605.044 SNMP agent item "ifOutOctets[eth0]" on host ".44 Ptera143" failed: first network error, wait for 15 seconds
    1654:20160817:094620.418 resuming SNMP agent checks on host ".44 Ptera143": connection restored
    1625:20160817:095446.238 SNMP agent item "ifOutOctets[lo]" on host ".44 Ptera130" failed: first network error, wait for 15 seconds
    1664:20160817:095501.653 resuming SNMP agent checks on host ".44 Ptera130": connection restored
    1630:20160817:100444.798 SNMP agent item "ifAdminStatus[lo]" on host ".44 Ptera130" failed: first network error, wait for 15 seconds
    1646:20160817:100459.059 resuming SNMP agent checks on host ".44 Ptera130": connection restored
    1630:20160817:101312.801 SNMP agent item "ifAdminStatus[tunl0]" on host ".46 Ptera125" failed: first network error, wait for 15 seconds
    1651:20160817:101327.987 resuming SNMP agent checks on host ".46 Ptera125": connection restored
    1628:20160817:101516.478 SNMP agent item "ifInOctets[br0]" on host ".47 Ptera138" failed: first network error, wait for 15 seconds
    1638:20160817:101531.052 resuming SNMP agent checks on host ".47 Ptera138": connection restored
    1628:20160817:102412.167 SNMP agent item "ifOutErrors[wifi0]" on host ".47 Ptera131" failed: first network error, wait for 15 seconds
    1663:20160817:102427.173 resuming SNMP agent checks on host ".47 Ptera131": connection restored
    1626:20160817:102512.848 SNMP agent item "ifInErrors[eth0]" on host ".47 Ptera138" failed: first network error, wait for 15 seconds
    1655:20160817:102527.212 resuming SNMP agent checks on host ".47 Ptera138": connection restored
    1635:20160817:102634.709 SNMP agent item "ifOperStatus[wifi0]" on host ".44 Ptera143" failed: first network error, wait for 15 seconds
    1654:20160817:102649.230 resuming SNMP agent checks on host ".44 Ptera143": connection restored
    I followed all the instructions that I could find on the forum and googling.
    Or is this something we need to pay to get fixed?
  • Ruddimaster
    • Dec 2016
    • 49
    I have exactly the same issue...
    I think the hardware is ok (HP DL380 Gen9)...
    top - 19:00:15 up 4:37, 1 user, load average: 0,09, 0,07, 0,07
    Tasks: 457 gesamt, 1 laufend, 455 schlafend, 0 gestoppt, 1 Zombie
    %CPU(s): 0,5 be, 0,1 sy, 0,0 ni, 99,3 un, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
    KiB Spch : 16298484 gesamt, 6355028 frei, 3209660 belegt, 6733796 Puff/Cache
    1294:20170105:194111.062 SNMP agent item "ifDescr" on host "Server2" failed: first network error, wait for 30 seconds
    1294:20170105:194133.082 resuming SNMP agent checks on host "Switch1": connection restored
    1296:20170105:194141.270 resuming SNMP agent checks on host "Switch2": connection restored
    1298:20170105:194203.261 SNMP agent item "hrProcessorLoad" on host "Switch2": first network error, wait for 30 seconds
    1360:20170105:194203.756 IPMI agent item "02-CPU1" on host "Server2" failed: first network error, wait for 30 seconds
    1351:20170105:194247.114 item "30456734-1234-1234-3230-353042285300:Fan1" became supported
    1294:20170105:194303.144 temporarily disabling SNMP agent checks on host "Switch2": host unavailable
    1294:20170105:194303.150 resuming IPMI agent checks on host "Server1": connection restored
    1294:20170105:194304.152 IPMI agent item "03-CPU2" on host "Server1" failed: first network error, wait for 30 seconds
    1353:20170105:194308.136 item "30456734-1234-1234-3230-353042285300":Fans" became supported
    set in zabbix_server.conf
    Timeout=30
    StartPollers=100
    In Administration -> "Queue" I see sometimes 3 items queued..
    Number of hosts (enabled/disabled/templates) 143 81 / 2 / 60
    Number of items (enabled/disabled/not supported) 6811 6277 / 23 / 511
    Number of triggers (enabled/disabled [problem/ok]) 2581 2551 / 30 [3 / 2548]
    Number of users (online) 9 2
    Required server performance, new values per second 100.41
    The same issue I have with IPMI...
    Zabbix 3.0.7.
    Zabbix Queue
    2017-01-05 19:37:52 1483641472 3
    2017-01-05 19:27:52 1483640872 98
    2017-01-05 19:17:52 1483640272 184
    2017-01-05 19:07:52 1483639672 187
    2017-01-05 18:57:52 1483639072 96
    2017-01-05 18:47:52 1483638472 184
    2017-01-05 18:37:52 1483637872 88
    2017-01-05 18:27:52 1483637272 97
    2017-01-05 18:17:52 1483636672 4
    2017-01-05 18:07:52 1483636072 0
    2017-01-05 17:57:52 1483635472 1
    2017-01-05 17:47:52 1483634872 1
    2017-01-05 17:37:52 1483634272 14
    2017-01-05 17:27:52 1483633672 2
    2017-01-05 17:17:52 1483633072 1
    2017-01-05 17:07:52 1483632472 0
    2017-01-05 16:57:52 1483631872 184
    2017-01-05 16:47:52 1483631272 0
    2017-01-05 16:37:52 1483630672 2
    2017-01-05 16:27:52 1483630072 1
    2017-01-05 16:17:52 1483629472 0
    2017-01-05 16:07:52 1483628872 93
    2017-01-05 15:57:52 1483628272 2
    2017-01-05 15:47:52 1483627672 0
    2017-01-05 15:37:52 1483627072 2
    Values processed by Zabbix server per second
    2017-01-05 19:39:57 1483641597 96.7451
    2017-01-05 19:38:57 1483641537 93.5207
    2017-01-05 19:37:57 1483641477 96.3181
    2017-01-05 19:36:57 1483641417 95.2895
    2017-01-05 19:35:57 1483641357 97.5815
    2017-01-05 19:34:57 1483641297 94.3979
    2017-01-05 19:33:57 1483641237 95.1267
    2017-01-05 19:32:57 1483641177 95.0379
    2017-01-05 19:31:57 1483641117 95.9417
    2017-01-05 19:30:57 1483641057 106.195
    2017-01-05 19:29:57 1483640997 92.7352
    2017-01-05 19:28:57 1483640937 96.6114
    2017-01-05 19:27:57 1483640877 95.9258
    2017-01-05 19:26:57 1483640817 95.5866
    2017-01-05 19:25:57 1483640757 95.3177
    2017-01-05 19:24:57 1483640697 94.2188
    2017-01-05 19:23:57 1483640637 95.1791
    2017-01-05 19:22:57 1483640577 95.4446
    2017-01-05 19:21:57 1483640517 95.6287
    2017-01-05 19:20:57 1483640457 94.8533
    2017-01-05 19:19:57 1483640397 96.9811
    2017-01-05 19:18:57 1483640337 96.8871
    Ubuntu 16.04.
    iftop within 2 minutes:
    TX: cum: 6,42MB peak: 835Kb
    RX: 9,32MB 1,80Mb
    TOTAL: 15,7MB 2,56Mb
    MySQL is on the same device.
    • Ruddimaster
      • Dec 2016
      • 49
      I had an other issue with mysql.
      I have set the max_connections to 2000, but this value does work. It stuck on 214.
      For this I have found these articles:
      and
      https://support.plesk.com/hc/en-us/articles/213393029
      Could it be to have the same problem with zabbix?
      • Ruddimaster
        • Dec 2016
        • 49
        Now I have a fresh installation on VMWare from scratch
        Ubuntu 16.04.1
        Zabbix 3.0.7
        I followed this guide (german)
        I added 6 HPE ILOs with VM Hypervisors on it.. + 2 Switches and 4 Routers + Zabbix server itself
        Zabbix server is running Yes localhost:10051
        Number of hosts (enabled/disabled/templates) 80 13 / 23 / 44
        Number of items (enabled/disabled/not supported) 2121 1882 / 0 / 239
        Number of triggers (enabled/disabled [problem/ok]) 382 326 / 56 [3 / 323]
        Number of users (online) 2 1
        Required server performance, new values per second 23.54
        (I have disabled the discovered guests)
        Now I have the same issue...!
        2923:20170107:180028.651 SNMP agent item "hrProcessorLoad" on host "IBNMJU11" failed: first network error, wait for 15 seconds
        2924:20170107:180029.990 SNMP agent item "hrStorageDescr" on host "IBNMJU12" failed: first network error, wait for 15 seconds
        2928:20170107:180055.653 SNMP agent item "hrProcessorLoad" on host "IBNMJU11" failed: another network error, wait for 15 seconds
        2926:20170107:180057.007 SNMP agent item "ifDescr" on host "IBNMJU12" failed: another network error, wait for 15 seconds
        2929:20170107:180059.898 SNMP agent item "ifDescr" on host "IBNMJU11" failed: another network error, wait for 15 seconds
        2930:20170107:180102.961 SNMP agent item "hrProcessorLoad" on host "IBNMJU12" failed: another network error, wait for 15 seconds
        2961:20170107:180105.957 item "123456789-1234-1234-1234-343330335235:C1P1IBay1" became supported
        2927:20170107:180107.009 SNMP agent item "hrStorageDescr" on host "IBNMJU12" failed: another network error, wait for 15 seconds
        2959:20170107:180108.961 item "123456789-1234-1234-1234-343330335235:C1P1IBay4" became supported
        2961:20170107:180112.966 item "123456789-1234-1234-1234-343330335235:C1P2IBay8" became supported
        2926:20170107:180126.020 temporarily disabling SNMP agent checks on host "IBNMJU11": host unavailable
        2970:20170107:180127.590 IPMI agent item "Fan3DutyCycle" on host "123456789-1234-1234-1234-343330335235" failed: first network error, wait for 15 seconds
        2929:20170107:180134.917 temporarily disabling SNMP agent checks on host "IBNMJU12": host unavailable
        2927:20170107:180143.203 resuming IPMI agent checks on host "123456789-1234-1234-1234-343330335235": connection restored
        2963:20170107:180146.985 item "123456789-1234-1234-1234-343330335235:SysHealthLED" became supported
        2951:20170107:180217.575 executing housekeeper
        2951:20170107:180217.593 housekeeper [deleted 0 hist/trends, 0 items, 0 events, 0 sessions, 0 alarms, 0 audit items in 0.017156 sec, idle for 1 hour(s)]
        2968:20170107:180232.644 IPMI agent item "Fan2" on host "123456789-1234-1234-1234-35304b485351" failed: first network error, wait for 15 seconds
        2926:20170107:180234.237 enabling SNMP agent checks on host "IBNMJU11": host became available
        2929:20170107:180242.962 enabling SNMP agent checks on host "IBNMJU12": host became available
        2927:20170107:180250.234 SNMP agent item "hrProcessorLoad" on host "IBNMJU11" failed: first network error, wait for 15 seconds
        2926:20170107:180250.255 IPMI agent item "Fan3" on host "123456789-1234-1234-1234-35304b485351" failed: another network error, wait for 15 seconds
        2929:20170107:180254.972 SNMP agent item "hrStorageDescr" on host "IBNMJU12" failed: first network error, wait for 15 seconds
        2927:20170107:180305.257 IPMI agent item "Fan5" on host "123456789-1234-1234-1234-35304b485351" failed: another network error, wait for 15 seconds
        2926:20170107:180317.270 SNMP agent item "ifDescr" on host "IBNMJU11" failed: another network error, wait for 15 seconds
        2927:20170107:180321.272 SNMP agent item "hrStorageDescr" on host "IBNMJU11" failed: another network error, wait for 15 seconds
        2928:20170107:180321.715 SNMP agent item "ifDescr" on host "IBNMJU12" failed: another network error, wait for 15 seconds
        2928:20170107:180324.016 resuming IPMI agent checks on host "123456789-1234-1234-1234-35304b485351": connection restored
        I have the same log entries like the productive environment (described above).
        Is this probably an issue with Ubuntu 16.04.1 LTS?
        • bbrendon
          • Sep 2005
          • 873
          and
          The # of connections zabbix makes to mysql is a littles less than the number of zabbix_server processes.
          Unofficial Zabbix Expert
          Blog, Corporate Site
          • Ruddimaster
            • Dec 2016
            • 49
            Yes you are right...
            ...but now it is set to 20.000 and zabbix use 600. But I have still this problem.
            The new installation has also (with less pollers) this issue.
            I am the only one with this combination Ubuntu 16.04.1 and 3.0.7. and this issue?
            • Mechanix
              • Jan 2017
              • 92
              I have the same issue with 3.2 and its driving me nuts.
              • kloczek
                • Jun 2006
                • 1771
                Such issues where many times discussed.
                It is not zabbix issue but performance issue on SNMP agent side.
                Try to query +10 times the same OID or set of OIDs and you will see that even using snmpget/snmpwalk you will see the same timeouts.
                You need to contact HPE or whatever HW vendor you are using support to resolve this issue.
