"No permissions to referred object or it does not exist!" message updating template
  • aseques
    • May 2019
    • 40
    I am updating the cisco template for an install based on 4.4 (now I'm on 6.4.7), everything is working normally but the newer templates are improved. When I started with this I had another issue that was present on 6.4.5 (fixed on 6.4.7), see here but it was fixed with the upgrade.
    But now I see this message when updating the template, and unfortunately there aren't any logs related to this in the log file.
    I am using the admin account so I discard the case o being a permission issues (that's most of the cases I saw in this forum about this message when people where doing API calls and scripting)
    So I would bet that it some object that should exist but it doesn't
    Any directions on this?
  • gcalenko
    Zabbix developer
    • Mar 2017
    • 27
    Can you provide more detailed info on template? It full name if it is unmodified Zabbix template.
    • aseques
      • May 2019
      • 40
      gcalenko I'm using the template from zabbix git here, unmodified. I attached the template I'm currently using (on the description it mentions version 0.15 but I couldn't find it on git)
      • MDE
        • May 2024
        Did you find the solution?
        I have the same error with zabbix 6.4.14.
