Zabbix SAML Username Attribute. Odd Behavior
  • Gsmith
    • Mar 2015
    • 56
    All,
    Zabbix-6.4.7 with Ubuntu-22.0.4 core installation.
    I've have been testing out different SSO applications. One application I was unable to modify or add a different user attribute (i.e., userName) so I used the application default one called "UserName". This actually worked. What i noticed after clicking " update" button was Zabbix placed someing different for a username attribute.
    For example: Below is three different nodes logging into the same Zabbix Web UI instance.
    please take note the username attribute I used is called "UserName"
    My personal lab environment.
    Click image for larger version  Name:	image.png Views:	0 Size:	85.1 KB ID:	472861
    My personal PC out side my lab.
    Click image for larger version  Name:	image.png Views:	0 Size:	72.5 KB ID:	472862
    Chrome incognito on my personal PC out side my lab, This is the only login that shows the correct Username attribute that I configured.
    Click image for larger version  Name:	image.png Views:	0 Size:	82.5 KB ID:	472863
    I tried to correct the top two screenshots but it revert back to either "Admin" or *. Not sure what going on, any suggestiosn or advice would be apperciated. Im assuming this maybe a bug?
    thanks in advance.​
  • gcalenko
    Zabbix developer
    • Mar 2017
    • 27
    Cannot reproduce on 6.4.7, first two screenshots looks like autosuggestion prefilled values. I would suggest to try to open in incognito mode.
    • Gsmith
      • Mar 2015
      • 56
      I confirmed it was Chrome autosuggestion prefilled values. Tested his on Firefox and works as expected.
