how to split string that contains more than one value
  • l.grube
    • Oct 2023
    Hi
    I have a value from my LENOVO switch
    Sensor 1: 41.0 C; Sensor 2: 25.5 C; Sensor 3: 34.25 C; Sensor 4: 43.75 C; Sensor 5: 33.25 C;
    how to split this string from zabbix ?
    thanks for your help.
    • 5004
    Split ? like each sensor to each own item?
    preprocessing ("right trim", remove last ; then "csv to json")
        "1": "Sensor 1: 41.0 C",
        "2": "Sensor 2: 25.5 C",
        "3": "Sensor 3: 34.25 C",
        "4": "Sensor 4: 43.75 C",
        "5": "Sensor 5: 33.25 C"
    +a bit of discovery (dependent), so you would get just right amount of items with item prototype (dependent item.. some jsonpath and regex preprocessing to extract just numbers).
