i can´t run zabbix on virtualbox :(
  • amanda
    • Aug 2016
    • 14
    well i tried to install zabbix on virtualbox because i have a project on my work, but it can run when i tried to start
    first i download the zabbix_appliance_3.0.4_x86_64.vmdk.tar and trie to run, and it works at the start but when i chose start zabbix the window still black and nothing happend, i dont know what happend i use a old windows machine with pentium 4 and 2 gb of ram with 32 bits
  • peatb
    • Aug 2016
    • 36
    I think your main isue is here:
    Originally posted by amanda
    first i download the zabbix_appliance_3.0.4_x86_64.vmdk.tar and .... i use a old windows machine with pentium 4 and 2 gb of ram with 32 bits
    a 64 bit template on a 32 bit host is not going to work.
    (wether the old machine is going to be powerfull enough is another question)
    • amanda
      • Aug 2016
      • 14
      think so, but whe i download any version it says the same _64 do you know if zabbix had a 32 bits version?
      • peatb
        • Aug 2016
        • 36
        When I look at the appliance links on the download page, they're all 64 bit so I think they only supply the appliance as 64 bit.
        You can download the packages in 32 bit, so if you want to use this hardware, you can download that (but you have to setup your own server).
