Cannot use Solaris 11 template for Zabbix 6LTS
  • TheReaper13
    • Jul 2021
    • 10
    Hello.
    I need to use a template under Zabbix 6LTS for Solaris systems. The official one (https://git.zabbix.com/projects/ZBX/...tes/os/solaris) would suit me, if it was not because it is for Zabbix 7. Where can I find the right template?
    Thanks.
  • Answer selected by TheReaper13 at 02-11-2023, 15:35.
    TheReaper13
    • Jul 2021
    • 10
    Solved. I was in a restrictive group and thus I could not see the full picture, otherwise it was all Ok. Thanks for the assistance.
      • 5004
      You mean this "Zabbix version: 7.0 and higher." ??
      Then maybe this one https://git.zabbix.com/projects/ZBX/...Frelease%2F6.0 ?
      • TheReaper13
        • Jul 2021
        • 10
        Hello.
        Thanks for the answer; I have tried that template but it does not work, it says 'Group "Templates/Operating systems" does not exist'. After looking a little at this installation (I have not done it), I find a pair of details:
        * There are only templates for databases, there is nothing else, as if they were not installed or just deleted on purpose;
        * I have no admin rights, I am just a plain user;
        Looks like I need to: 1) become admin; and 2) install all of them, which I have extracted from the own install sources. I will post progress here.​
          • 5004
          As a ordinary user, you may not see other groups and templates. Becoming admin gives you admin rights within your access restrictions (ie those groups, what you can see).
          Super admin is the one, who sees it all...
          • TheReaper13
            • Jul 2021
            • 10
