Passive Server with UserParameters and Unsupported item key.
  • kylereese
    • Nov 2023
    I have an agent which is set to run as a passive most because the server is unable to reach the agent, but the other way works fine. Normal Zabbix metrics like CPU and memory are working. However any of my custom checks are failing. I have confirmed with the command below that the command locally works. My config for the agent is below.
    zabbix_agentd -t "gpu.temp[0]" -c /etc/zabbix/zabbix_agentd.conf
    gpu.temp[0] [t|31]​
    In the server the host is configured using the Linux by Zabbix agent Template which as stated above, is working.
    ​PidFile=/run/zabbix/zabbix_agentd.pid
    LogFile=/var/log/zabbix/zabbix_agentd.log
    LogFileSize=0
    ##### Passive checks related
    Server=REDACTED
    Hostname=NVIDIA02
    DebugLevel=3
    ############ ADVANCED PARAMETERS #################
    Include=/etc/zabbix/zabbix_agentd.d/*.conf
    UserParameter=gpu.temp[*],nvidia-smi --query-gpu=temperature.gpu --format=csv,noheader,nounits -i $1
    UserParameter=gpu.memtotal[*],nvidia-smi --query-gpu=memory.total --format=csv,noheader,nounits -i $1
    UserParameter=gpu.used[*],nvidia-smi --query-gpu=memory.used --format=csv,noheader,nounits -i $1
    UserParameter=gpu.free[*],nvidia-smi --query-gpu=memory.free --format=csv,noheader,nounits -i $1
    UserParameter=gpu.fanspeed[*],nvidia-smi --query-gpu=fan.speed --format=csv,noheader,nounits -i $1
    UserParameter=gpu.utilisation[*],nvidia-smi --query-gpu=utilization.gpu --format=csv,noheader,nounits -i $1
    UserParameter=gpu.power[*],nvidia-smi --query-gpu=power.draw --format=csv,noheader,nounits -i $1​
    • 4996
    First thing as usual... check the logs... Both server and agent logs. See, if there is anything related...
    Are you really sure your other items (CPU etc) are also passive items? I kind of fail to see, how it would be possible to obtain some values and not the others, if they all are "passive"...
