Trigger issue with dependant items and/or extra "operational data" ...
  • MickeyPM
    • Apr 2020
    • 13
    We are having a bit of a catch-22 issue related to triggers with dependant items and/or extra "operational data" ...
    ISSUES:
    Issue 1:
    A triggers with "PROBLEM event generation mode" = "Multiple" execute for each dependent item updated, and does not scope to the initail parent item update.
    Issue 2:
    A trigger "operational data" cannot reference other items data that is not in the trigger expression.
    OVERVIEW:
    ITEMS:
    a) "Parent" Item
    We have created a "Parent" ITEM of type "Zabbix Agent (active)" that runs every 15 minutes
    and it executes a user.parameter script to scan varoius logs for a list of keywords and then return the results in a dataset
    { "logs": { "count": "11 , "detail": "7 x (SYSTEM ERROR)\n4 x (MEMORY VIOLATION)" } }​
    [This is done to replace the limiting "logrt" check we currently use]
    b) Dependent Items
    There are then 2 Dependent Items to extract the "Count" and "Detail" values from the dataset using a JSONPath preprocessing step.
    EXPECTED OUTCOME:
    As each check will return a NEW response, we want to create a NEW event/problem for each check, and send a new Notification with the new detail included.
    Alert Example:
    Subject: Problem: Logs contains errors (11 in the last 15 minutes)
    Message:
    Operational data: 11 Errors
    7 x (SYSTEM ERROR)
    TRIGGERS:
    To ensure we get a new alert for each check preformed, the "PROBLEM event generation mode" must be set to "Multiple",
    as "Single" will not create another problem until the previous one is resolved/closed.
    Issue 1:
    If we include ONLY the "Count" in the expression, the "Detail" can not be displayed in the "Operational Data"
    Issue 2:
    If we include BOTH the "Count" and the "Detail" in the expression then the Triggers fires TWICE, as each "Dependent" item is updated
    14:50:47 High PROBLEM Logs contains errors (11 in the last 15 minutes)
    14:35:46 High PROBLEM Logs contains errors (3 in the last 15 minutes)
    Any assistance or guidance would be greatly appreciated !
    Regards
    Pieter.
