Cannot Parse OID Error
  • Mr.Phreak
    • Jun 2016
    Hey Guys,
    Having problems with some Private MIBs not resolving. Showing snmp_parse_oid(): cannot parse OID "MIKROTIK-MIB::mtxrHlVoltage.0"
    MIBs are all in /usr/share/snmp/mibs and are defined in /usr/share/snmp/snmp.conf
    [zabbix@zabbix ~]$ net-snmp-config --snmpconfpath
    /etc/snmp:/usr/share/snmp:/usr/lib64/snmp:/home/zabbix/.snmp:/var/lib/net-snmp
    [zabbix@zabbix ~]$ net-snmp-config --default-mibdirs
    /home/zabbix/.snmp/mibs:/usr/share/snmp/mibs
    All the standard ones from Template SNMP Device appear to work (such as SNMPv2-MIB::sysContact.0)
    Running snmpget from the terminal works
    [zabbix@zabbix ~]$ snmpget -v2c -c public 192.168.127.254 MIKROTIK-MIB::mtxrHlVoltage.0
    MIB search path: /home/zabbix/.snmp/mibs:/usr/share/snmp/mibs
    MIKROTIK-MIB::mtxrHlVoltage.0 = INTEGER: 27.4
    Just hoping someone can point me in the right direction as to where to start looking.
    Cheers,
    Darryn.
  • Mr.Phreak
    • Jun 2016
    Also after some looking around, find the following errors in the zabbix_server.log
    /usr/share/snmp/mibs/MIKROTIK-MIB.txt: Permission denied
    MIB search path: $HOME/.snmp/mibs:/usr/share/snmp/mibs
    Cannot find module (MIKROTIK-MIB): At line 1 in (none)
    It appears to have the same permissions as the standard mibs which work fine.
    -rw-r--r--. 1 root root    64817 Aug 21 18:38 MIKROTIK-MIB.txt
    -rw-r--r--. 1 root root    29305 May 13 01:14 SNMPv2-MIB.txt
    • SomeDude79
      • Feb 2020
      Hey Guys,
      I know this an old question but has anyone else comme across this problem?
      Mr. Phreak, where you able to resolve it?
      I am having the same issue and am trying to find a solution.
      Thank you
