Appliance - Zabbix 6.4.8 - DB not starting up (tried .qcow2 and ISO INSTALL)
  • chrisfb
    • May 2013
    • 10
    As per subject. I Have tried QCOW2 and ISO install It's all installed OK but DB does not start. Error log in both cases:
    2023-11-14T00:04:02.069841Z 0 [Warning] [MY-010918] [Server] 'default_authentication_plugin' is deprecated and will be removed in a future release. Please use authentication_policy instead.
    2023-11-14T00:04:02.069890Z 0 [System] [MY-010116] [Server] /usr/libexec/mysqld (mysqld 8.0.32) starting as process 2642
    2023-11-14T00:04:03.103013Z 0 [Warning] [MY-013907] [InnoDB] Deprecated configuration parameters innodb_log_file_size and/or innodb_log_files_in_group have been used to compute innodb_redo_log_capacity=536870912. Please use innodb_redo_log_capacity instead.
    2023-11-14T00:04:03.106207Z 1 [System] [MY-013576] [InnoDB] InnoDB initialization has started.
    2023-11-14T00:04:03.992756Z 1 [ERROR] [MY-012960] [InnoDB] Cannot create redo log files because data files are corrupt or the database was not shut down cleanly after creating the data files.
    2023-11-14T00:04:04.258110Z 1 [ERROR] [MY-010334] [Server] Failed to initialize DD Storage Engine
    2023-11-14T00:04:04.258550Z 0 [ERROR] [MY-010020] [Server] Data Dictionary initialization failed.
    2023-11-14T00:04:04.258594Z 0 [ERROR] [MY-010119] [Server] Aborting
    2023-11-14T00:04:04.259420Z 0 [System] [MY-010910] [Server] /usr/libexec/mysqld: Shutdown complete (mysqld 8.0.32) Source distribution.
    Main error seems to be:
    Seems like a DB dump wasn't done correctly. Can I fix it myself somehow?
    Chris
