Documenting what I have found to work for VMware ESX host and HPE Synergy 480 Gen10 Plus SNMP monitoring. For the ESX host monitoring, create a host for your vCenter. Assign the template: VMware. Also, for the host add the following Macros: {$VMWARE.PASSWORD}, {$VMWARE.URL}, {$VMWARE.USERNAME}. Once added, this will add the discovered Clusters, ESX hosts, and VMs. If you want to exclude the discovery of VMs or other items, go to the Discovery Rules for the vCenter host and disable that rule. For monitoring the hardware, this can be done via the ILO SNMP. On the ILO, setup the snmpv3 user setting authentication to SHA and Privacy to AES. For the host on Zabbix, set the Template to: HPE Proliant DL380 SNMP, add the interface with type SNMP, snmpv3, security level: authPriv, security name (user added in ILO), authentication protocol: SHA1, Privacy protocol: AES128, all with corresponding passphrases.
Templates for VMware ESX hosts and HP Synergy 480 Gen10 Plus SNMP
