Preprocessing failed due to SyntaxError in (valid) JSON?
  • viktorkho
    • Jul 2013
    • 90
    I'm going to make host LLD from JSON-over-HTTP data. The issue looks quite simple, but.. I receive a SyntaxError from my Zabbix 6.4.8
    Preprocessing failed for: [.. {.. "Id": "48edc41c-0000-0000-ac7b-58cc77c9092d",.. "Name": "F-12",.. "Type": "Farm...
    1. Failed: SyntaxError: parse error (line 3)​
    and I have no idea whether the error relates to JS-preprocessing, the JSON, or just a bug​.. or what I am doing wrong?
    I've tested my preprocessing with https://www.jdoodle.com/ia/R5G
    The JSON document passes validation on https://jsonformatter.org/json-parser/af2e0e, I pastebined it https://pastebin.com/raw/ijH5kacA and this URL is hardcoded in this test template:
    zabbix_export:
      version: '6.4'
      template_groups:
        - uuid: ea8da0a2b67548b2984e3db9e32283e3
      host_groups:
        - uuid: c0b64a45e6b344b38576b90e0823dfba
      templates:
        - uuid: 7f897c9d7a894e709a1de601260ae373
          template: 'Test Preprocessing failed SyntaxError'
          name: 'Test Preprocessing failed SyntaxError'
          groups:
            - name: Templates/Test
          discovery_rules:
            - uuid: f759f7fa15c14a72895b293bcc3c8c8d
              type: HTTP_AGENT
              key: houses
              host_prototypes:
                - uuid: a5bdda6c16b8408ebe116cb34b824302
                  host: '{#LOCATION_ID}'
                  group_links:
                    - group:
              url: 'https://pastebin.com/raw/ijH5kacA'
              lld_macro_paths:
                - lld_macro: '{#LOCATION_ID}'
                  path: $.Id
                - lld_macro: '{#LOCATION_NAME}'
                  path: $.Name
              preprocessing:
                - type: JAVASCRIPT
                  parameters:
                      // Get Houses Id and Name
                      var params = JSON.parse(value)
                      return JSON.stringify(params[0].Children.map((house) => ({"Id": house.Id, "Name": house.Name})))
                - type: STR_REPLACE
                  parameters:
    Can you please check whats wrong?​
  • viktorkho
    • Jul 2013
    • 90
    Seems that Duktape (https://duktape.org/api.html) doesn't support `map()` syntax, so "SyntaxError: parse error" is about JS-code parsing, not ingesting JSON
    • markfree
      • Apr 2019
      • 875
      I think it was a bit unclear of what preprocessing you are trying to use and what kind of data you are trying to extract from your JSON.
      I would also point out that a template Yaml is not the best option to present your preprocessing steps. A simple print of your item would suffice.
      Anyway, as your template shows, your JavaScript preprocessing step is the following.
      And when you test it, the error is this.
      Right?
      So, why are you parsing the JSON with JavaScript when you can use JSONPath?​
        • 5004
        I think he is trying to format check output as json (JSON.stringify... ) and after that point LLD macros to certain paths in json (path: $.Id, path: $.Name)​
        • markfree
          • Apr 2019
          • 875
          I thought the original value was a JSON already.​
