Hi Experts,
I installed zabbix server 3.0.4 on my linux box and I am using Mariadb MYSQL as the database. However when I try connecting to its setup page, I get the below error :-
Configuration file error
DB type "MYSQL" is not supported by current setup. Possible values .
Below are the config files for zabbix :-
cat /etc/zabbix/zabbix_server.conf
DBHost=localhost
DBName=abc_db
DBUser=abc_user
DBPassword=abc
cat /etc/zabbix/web/zabbix.conf.php
<?php
// Zabbix GUI configuration file.
global $DB;
$DB['TYPE'] = 'MYSQL';
$DB['SERVER'] = 'localhost';
$DB['PORT'] = '0';
$DB['DATABASE'] = 'abc_db';
$DB['USER'] = 'abc_user';
$DB['PASSWORD'] = 'abc';
// Schema name. Used for IBM DB2 and PostgreSQL.
$DB['SCHEMA'] = '';
$ZBX_SERVER = 'localhost';
$ZBX_SERVER_PORT = '10051';
$ZBX_SERVER_NAME = 'zzzz';
$IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
cat /etc/httpd/conf.d/zabbix.conf
# Zabbix monitoring system php web frontend
Alias /zabbix /usr/share/zabbix
<Directory "/usr/share/zabbix">
Options FollowSymLinks
AllowOverride None
Require all granted
# Require ip 127.0.0.1 192.168.101.0/24
<IfModule mod_php5.c>
php_value max_execution_time 300
php_value memory_limit 128M
php_value post_max_size 16M
php_value upload_max_filesize 2M
php_value max_input_time 300
php_value always_populate_raw_post_data -1
php_value date.timezone Asia/Kolkata
</IfModule>
</Directory>
<Directory "/usr/share/zabbix/conf">
Require all denied
</Directory>
<Directory "/usr/share/zabbix/include">
Require all denied
</Directory>
And zabbix log when I restart the zabbix services
7155:20160903:204936.240 Got signal [signal:15(SIGTERM),sender_pid:4752,sender_uid:0,re ason:0]. Exiting ...
4756:20160903:204936.251 Starting Zabbix Server. Zabbix 3.0.4 (revision 61185).
4756:20160903:204936.251 ****** Enabled features ******
4756:20160903:204936.251 SNMP monitoring: YES
4756:20160903:204936.251 IPMI monitoring: YES
4756:20160903:204936.251 Web monitoring: YES
4756:20160903:204936.251 VMware monitoring: YES
4756:20160903:204936.251 SMTP authentication: YES
4756:20160903:204936.251 Jabber notifications: YES
4756:20160903:204936.251 Ez Texting notifications: YES
4756:20160903:204936.251 ODBC: YES
4756:20160903:204936.251 SSH2 support: YES
4756:20160903:204936.251 IPv6 support: YES
4756:20160903:204936.251 TLS support: YES
4756:20160903:204936.251 ******************************
4756:20160903:204936.251 using configuration file: /etc/zabbix/zabbix_server.conf
4756:20160903:204936.253 current database version (mandatory/optional): 03000000/03000000
4756:20160903:204936.253 required mandatory version: 03000000
4756:20160903:204936.257 listener failed: zbx_tcp_listen() fatal error: unable to serve on any address [[127.0.0.1]:10051]
zabbix_server [7155]: [file:'dbconfig.c',line:5524] lock failed: [43] Identifier removed
4767:20160903:204946.268 Starting Zabbix Server. Zabbix 3.0.4 (revision 61185).
4767:20160903:204946.268 ****** Enabled features ******
4767:20160903:204946.268 SNMP monitoring: YES
4767:20160903:204946.268 IPMI monitoring: YES
4767:20160903:204946.268 Web monitoring: YES
4767:20160903:204946.268 VMware monitoring: YES
4767:20160903:204946.268 SMTP authentication: YES
4767:20160903:204946.268 Jabber notifications: YES
4767:20160903:204946.268 Ez Texting notifications: YES
4767:20160903:204946.268 ODBC: YES
4767:20160903:204946.268 SSH2 support: YES
4767:20160903:204946.268 IPv6 support: YES
4767:20160903:204946.268 TLS support: YES
4767:20160903:204946.268 ******************************
4767:20160903:204946.268 using configuration file: /etc/zabbix/zabbix_server.conf
4767:20160903:204946.273 current database version (mandatory/optional): 03000000/03000000
4767:20160903:204946.273 required mandatory version: 03000000
4767:20160903:204946.277 server #0 started [main process]
4772:20160903:204946.277 server #1 started [configuration syncer #1]
4773:20160903:204946.278 server #2 started [db watchdog #1]
4774:20160903:204946.278 server #3 started [poller #1]
4776:20160903:204946.278 server #4 started [poller #2]
4777:20160903:204946.278 server #5 started [poller #3]
4778:20160903:204946.278 server #6 started [poller #4]
Please suggest if I am missing something here or doing anything silly. Appreciate all your help and time on this.
Thanks in advance.
DBHost=localhost
DBName=abc_db
DBUser=abc_user
DBPassword=abc
<?php
global $DB;
$DB['PORT'] = '0';
$DB['SCHEMA'] = '';
AllowOverride None
Require all granted
</IfModule>
</Directory>
Require all denied
</Directory>
Require all denied
</Directory>
Thanks in advance.
