Problema after upgrading Zabbix to 6.0
  • stepassia
    • Feb 2018
    • 27
    Hi, I've upgraded my Zabbix to 6.0 LTS version. I've a mariadb as db server with partitions activate.
    Checking the tables I can see that the history tables didn't have any primary key... so, I repair it?
    I need to deactivate partitioning, redo the procedure and than reactivate partitioning? or it will be enough add the primary keys to the current tables?
    Stefano
  • markfree
    • Apr 2019
    • 875
    Since Zabbix 6.0, primary keys are used for all tables in new installations.
    Check out these instructions for upgrading your database.
