Problem getting data from Amazon S3 Bucket
  • Brett-8149
    • Nov 2023
    Hi All,
    I'm having problems when getting data while using the AWS by HTTP template to retrieve information on an S3 bucket.
    The connection has been established correctly and from both ends I can see the connection is working and data is being requested.
    When running a test on the template the bucket is retrieved as expected, however no data is being pulled in
    I've added the access key policy from here: https://www.zabbix.com/integrations/aws
    I'm running Zabbix 6.0 LTS
    The only data which appears to be checked by the plugin are
    - Get alarms check
    - Get metrics check
    However neither of these have any values
    Any advise on what I might have missed?
    Cheers
