vfs.fs.size and large external drives on macOS not reporting properly?
  • sphen
    • Dec 2013
    • 25
    good day.
    long time zabbix user - just noticed that on some newer macOS devices (13+) that the vfs.fs.size key reports the wrong values. It is seemingly maxed out to some degree at a much lower value than the 64-bit unsigned integer should hold. has anyone noticed this? I could build some custom keys to get the proper values via some other means but i am wondering why this is happening.
    some examples:
    /dev/disk5s1 16Ti 1.1Ti 15Ti 7% 713 164070039840 0% /Volumes/G-DRIVE
    but zabbix_get gets:
    zabbix_get -s 127.0.0.1 -p 10050 -k 'vfs.fs.size["/Volumes/G-DRIVE",total]'
    407812136960
    ~ 408 GB
    on another machine i have:
    /dev/disk9s1 16Ti 57Gi 16Ti 1% 1.9k 175G 0% /Volumes/18 TB OWC Gemini RAID
    /dev/disk7s1 16Ti 3.7Ti 13Ti 23% 1.0M 136G 0% /Volumes/18 TB WD RAID
    but they report:
    zabbix_get -s 127.0.0.1 -p 10050 -k 'vfs.fs.size["Volumes/18 TB OWC Gemini RAID",total]'
    407778582528
    zabbix_get -s 127.0.0.1 -p 10050 -k 'vfs.fs.size["Volumes/18 TB WD RAID",total]'
    407677894656
    thank you!
    ​oh also pfree does not work...
    zabbix_get -s 127.0.0.1 -p 10050 -k 'vfs.fs.size["Volumes/18 TB WD RAID",pfree]'
    0.000000
