I have server with Ubuntu 14.04 LTS and zabbix-server-mysql 3.0.4
I try to add the functionality to send SMS. I use script from smseagle.
Script work properly from console.
I added script to zabbix
- Administration>Media types>add script
- Administration>Users>add new media.
- Configuration>Actions>add operations
Zabbix dashboard show that alert send, but nothing on smsgateway.
I capture traffic and doesn't see any packet to smsgateway.
Zabbix log with 5lvl debug doesn't help.
Dear colleagues, would you kindly help with this issue.
Thank you in advance.
#!/usr/bin/php
<?php
* cli_smseagle.php
* Script to send an SMS via
* SMSEagle - sms hardware gateway
* Version : 1.1
* Date : Nov 23 2015
* Author : Radoslaw Janowski / WWW.SMSEAGLE.EU
* License: BSD
* Copyright (c) 2013-2015, SMSEagle www.smseagle.eu
//Set the following values:
$smseagle_ip = "192.168.0.102";
$login = "smseagleuser";
$password = "smseaglepassword";
$timezone = "Europe/Warsaw";
//available timezones can be found here: http://www.php.net/manual/en/timezones.php
// Debugging?
$debug = false;
do not change below unless you know what you are doing
date_default_timezone_set($timezone);
if (count($argv)<3) {
die ("Usage: ".$argv[0]." recipientmobilenumber \"subject\" \"message\"\n");
if ( $debug ) file_put_contents("/tmp/smseagle_".date("YmdHis"), serialize($argv));
$to = $argv[1];
$message = $argv[2];
if ( $message == "" || !is_numeric($to) ) {
die("missing params!\n");
$apiargs = array(
"login" => $login,
"pass" => $password,
"to" => $to,
"message" => $message
$url = "http://".$smseagle_ip."/index.php/http_api/send_sms?";
$params = "";
foreach ($apiargs as $k=>$v) {
if ( $params != "" ) {
$params .= "&";
$params .= $k."=".urlencode($v);
$url .= $params;
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, $url );
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, 0);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, 1);
$result = curl_exec($curl);
if ( $result === false ) {
file_put_contents("/tmp/smseagle_error_".date("YmdHis"), curl_error($curl));
die(curl_error($curl)."\n");
} else {
if ( $debug || $result != 100 ) file_put_contents("/tmp/smseagle_answer_".date("YmdHis"), $result);
