Switching red messages
  • dabenavidesd
    • Sep 2016
    • 15
    Hello all:
    I wonder if you can make a suggestion of whatever could be wrong in an 2.0 Zabbix, for which I have trying to add an agent (passive) of a Win Server; one of the messages is:
    Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer
    other times it says Interrupted system call also in red after changing client conf file.
    Can anyone make an asseveration of what is going on?
    Thanks in advance
  • dabenavidesd
    • Sep 2016
    • 15
    OK now
    Hello people:
    I had bad values in zabbix_agentd.conf; namely use of IPs address; using names instead in Server, etc, I could make it work.
    thanks for your hard work.
