LLD issue - value is showing in key
  • jan.motejzik
    • Nov 2022
    Hello, I would like to ask about a problem that I have been struggling with for several days.
    I would like to monitor the values from the json file, specifically the number of days remaining until the end of the expiration. I think I have a problem with the LLD settings, the value that should appear for a specific item as value is displayed in the key and there is Parameter is not allowed error.
    1) python script returns me data in json:
    HTML Code:
            "{#ROBOT}": "Alfa",
            "{#DAYS}": "63"
            "{#ROBOT}": "Gamma",
            "{#DAYS}": "14"
            "{#ROBOT}": "Delta",
            "{#DAYS}": "19"
    2)
    discovery rule:
    key: rpa.status
    item prototype:
    key: rpa.status[{#DATE}]
    3)
    zabbix agent:
    UserParameter=rpa.status,cat /opt/zabbix/test (just for test purposes)​
    what am I missing? thanks for the hints !
    • 5004
    UserParameter=rpa.status[*],cat.....
    • jan.motejzik
      • Nov 2022
      thanks. now I see whole json as a value in latest data ..
      do I setup lld macros correctly?
      thanks
        • 5004
        You already have them in there. Just like built in block devices discovery returns json with formatted LLD macros. (https://www.zabbix.com/documentation...amples/devices).
        No need to define any others... (and what you defined there does not exist in your json.., there is no key called "robot" )
        • jan.motejzik
          • Nov 2022
          thank you for your reply, however, despite creating several templates, I don't understand why this one still doesn't work for me ..
          I was editing the UserParameter for zabbix agent:
          UserParameter=rpa.status[*],....
          but dont get, why I didnt get the right value ....
          could you please help me with these settings ?
          thanks​
            • 5004
            Wait... you want that this userparameter would pull correct number via that python script, which outputs that json in first post?
            • jan.motejzik
              • Nov 2022
              I have python script which returns me json file from first post. From json I need monitor a value from {#DAYS} section, which is number of days to expire.....
              as u can see at the screenshots, like a last value there is nothing instead of number of expire days ...
              at the screenshots u can see my whole settings ...
              User Parameter is UserParameter=rpa.check[*],python3.9 /opt/script.py
              thanks for helping ..
              Click image for larger version  Name:	Screenshot_23.png Views:	0 Size:	13.9 KB ID:	475416 Click image for larger version
              Click image for larger version  Name:	image.png Views:	0 Size:	30.4 KB ID:	475420​
              • jan.motejzik
                • Nov 2022
                json from script:
                "{#ROBOT}": "Alfa",
                "{#DAYS}": "63"
                "{#DAYS}": "14"
                "{#DAYS}": "19"
