Zabbix server is running (Value = No)
  • gwangjong
    • Oct 2023
    • 11
    Hi Guys,
    Good day!
    Seeking for your help regarding on this concern.
    I'm getting this kind of messages in systemctl status zabbix-server.service
    I've been using Cent OS 7,version of zabbix is 5.0TLS, for the web front end is Apache.
    Thank you!
  • LenR
    • Sep 2009
    • 1011
    Look at zabbx-server.log. It's probably not running because of configuration errors.
    That image is pretty much unreadable....
    • gwangjong
      • Oct 2023
      • 11
      Hello LenR
      Good day!
      As I look into the zabbix-server.log
      out of memory (requested 108424 bytes)
      please increase CacheSize configuration parameter
      Is this the possible root cause of the error ?
      How can I increase the CacheSize configuration ?
      I'm kinda new to this enironment, Thank you for the support!
      • solution
        • Jun 2020
        • 272
        Increases the cache in the Zabbix Server configuration file.
        /etc/zabbix/zabbix_server.conf
        CacheSize=
        HistoryCacheSize=
        HistoryIndexCacheSize=
        TrendCacheSize=
        ValueCacheSize=
        Parameters Supported: https://www.zabbix.com/documentation.../zabbix_server
        Restart the Zabbix Server service
        Wellington​
        • gwangjong
          • Oct 2023
          • 11
          Hello solution,
          Good day!
          Before my CacheSize is only 8M, as suggested, I changed it into 64M. Zabbix server already in UP state.
          As of now, these are my configurations for these items below.
          CacheSize= 64M
          HistoryCacheSize= 16M
          HistoryIndexCacheSize= 4M
          TrendCacheSize= 4M
          ValueCacheSize= 8M
          Should I increase them as well? The range is 128K-64G
          Thank you for the support guys!
          • solution
            • Jun 2020
            • 272
            Continue monitoring and increase only when necessary.
            Wellington
            • LenR
              • Sep 2009
              • 1011
              Add the Zabbix server template to monitor the zabbix server. It will show these values.
