AWS S3 by HTTP not working?
  • Javivu
    • Aug 2023
    • 12
    #16
    Only for testing, a "patch" or "workaround" if you dont need filter_id in Amazon S3, do this changes in:
    • Template: AWS S3 bucket by HTTP
    • Item: AWS S3: Get metrics data
    • Script: modifies:
    try {
        AWS.setParams(JSON.parse(value));
        var region = AWS.getBucketLocation(AWS.params.bucket_name),
              metrics = AWS.getMetricsData(region),
              filter_id = AWS.getBucketFilterId(AWS.params.bucket_name, region);
        return JSON.stringify({ metrics, filter_id });
    With this code:
    try {
              metrics = AWS.getMetricsData(region);
        return JSON.stringify({ metrics });
    Bye
    • Markku
      • Sep 2018
      • 1784
      #17
      Btw did you do this (just checking as you didn't specifically mention it I think):
      To gather Request metrics, enable Requests metrics on your Amazon S3 buckets from the AWS console.​
      And, did your changes above lead to your metrics working?
      Markku
      • Javivu
        • Aug 2023
        • 12
        #18
        Yes correct, I had it activated. By "deleting" the query that gave an error (AWS.getBucketFilterId), the data is obtained correctly: bucket objects and storage​
