Probleme from upgrade zabbix 3.0 to 3.2 with database monitor
  • colloque
    • Feb 2010
    • 72
    I have a problem with zabbix 3.2 avec a database monitor.
    My Query SQL is:
    select round(b.bytes_free) "free B"
    from ( select f.tablespace_name,
    sum(f.bytes) bytes_alloc,
    sum(decode(f.autoextensible, 'YES',f.maxbytes,'NO',
    f.bytes)) maxbytes
    from dba_data_files f
    group by tablespace_name) a,
    sum(f.bytes) bytes_free
    from dba_free_space f
    group by tablespace_name) b
    where a.tablespace_name = b.tablespace_name and a.tablespace_name='CAT_DATA'
    information
    Numeric (unsigned)
    Decimal
    B
    Now since the upgrade to zabbix 3.2 i have the following error (see attachment file)
    Do you have an idea ?
    Thanks in advance
  • colloque
    • Feb 2010
    • 72
    I have applied the PATCH:
    ZBX-11213.patch
    and it works now.
    Thanks.
    • mark.chan
      • Mar 2016
      • 35
      Could you teach me/tell me where I can know how to install the patch?
      Many Thanks.
      • scarrijo
        • May 2014
        I have the same problem
        after upgrading from 3.0 to 3.2 all the triggers I had stopped working, and those ones that has a decimal value as a return has status as Not Supported .
        • GPegel
          • Dec 2015
          • 113
          I had the exact same problem. This morning I did a "yum update" on my CentOS servers and I saw the newest update for Zabbix Server and that solved my problem. I've upgraded from 3.0.5 to 3.2.2 and all works well now.
