Hi, I have used Zabbix 5.0, 5.4, 6.0, and 6.2. Currently, I am experiencing version 6.4, but the network discovery rule is not working. What could be the reason? My configuration file is as follows
# This is a configuration file for Zabbix server daemon
# To get more information about Zabbix, visit http://www.zabbix.com
### Option: ListenPort
# Listen port for trapper.
# Mandatory: no
# Range: 1024-32767
# Default:
# ListenPort=10051
### Option: SourceIP
# Source IP address for outgoing connections.
# Mandatory: no
# Default:
# SourceIP=
### Option: LogType
# Specifies where log messages are written to:
# system - syslog
# file - file specified with LogFile parameter
# console - standard output
# Mandatory: no
# Default:
# LogType=file
### Option: LogFile
# Log file name for LogType 'file' parameter.
# Mandatory: yes, if LogType is set to file, otherwise no
# Default:
# LogFile=
LogFile=/var/log/zabbix/zabbix_server.log
### Option: LogFileSize
# Maximum size of log file in MB.
# 0 - disable automatic log rotation.
# Mandatory: no
# Range: 0-1024
# Default:
# LogFileSize=1
LogFileSize=0
### Option: DebugLevel
# Specifies debug level:
# 0 - basic information about starting and stopping of Zabbix processes
# 1 - critical information
# 2 - error information
# 3 - warnings
# 4 - for debugging (produces lots of information)
# 5 - extended debugging (produces even more information)
# Mandatory: no
# Range: 0-5
# Default:
# DebugLevel=3
### Option: PidFile
# Name of PID file.
# Mandatory: no
# Default:
# PidFile=/tmp/zabbix_server.pid
PidFile=/run/zabbix/zabbix_server.pid
### Option: SocketDir
# IPC socket directory.
# Directory to store IPC sockets used by internal Zabbix services.
# Mandatory: no
# Default:
# SocketDir=/tmp
SocketDir=/run/zabbix
### Option: DBHost
# Database host name.
# If set to localhost, socket is used for MySQL.
# If set to empty string, socket is used for PostgreSQL.
# If set to empty string, the Net Service Name connection method is used to connect to Oracle database; also see
# the TNS_ADMIN environment variable to specify the directory where the tnsnames.ora file is located.
# Mandatory: no
# Default:
DBHost=10.****
### Option: DBName
# Database name.
# If the Net Service Name connection method is used to connect to Oracle database, specify the service name from
# the tnsnames.ora file or set to empty string; also see the TWO_TASK environment variable if DBName is set to
# empty string.
# Mandatory: yes
# Default:
# DBName=
DBName=zabbix
### Option: DBSchema
# Schema name. Used for PostgreSQL.
# Mandatory: no
# Default:
# DBSchema=
### Option: DBUser
# Database user.
# Mandatory: no
# Default:
# DBUser=
DBUser=zabbix
### Option: DBPassword
# Database password.
# Comment this line if no password is used.
# Mandatory: no
# Default:
DBPassword=*******
### Option: DBSocket
# Path to MySQL socket.
# Mandatory: no
# Default:
# DBSocket=
### Option: DBPort
# Database port when not using local socket.
# If the Net Service Name connection method is used to connect to Oracle database, the port number from the
# tnsnames.ora file will be used. The port number set here will be ignored.
# Mandatory: no
# Range: 1024-65535
# Default:
DBPort=5432
### Option: AllowUnsupportedDBVersions
# Allow server to work with unsupported database versions.
# 0 - do not allow
# 1 - allow
# Mandatory: no
# Default:
# AllowUnsupportedDBVersions=0
### Option: HistoryStorageURL
# History storage HTTP[S] URL.
# Mandatory: no
# Default:
# HistoryStorageURL=
### Option: HistoryStorageTypes
# Comma separated list of value types to be sent to the history storage.
# Mandatory: no
# Default:
# HistoryStorageTypes=uint,dbl,str,log,text
### Option: HistoryStorageDateIndex
# Enable preprocessing of history values in history storage to store values in different indices based on date.
# 0 - disable
# 1 - enable
# Mandatory: no
# Default:
# HistoryStorageDateIndex=0
### Option: ExportDir
# Directory for real time export of events, history and trends in newline delimited JSON format.
# If set, enables real time export.
# Mandatory: no
# Default:
# ExportDir=
### Option: ExportFileSize
# Maximum size per export file in bytes.
# Only used for rotation if ExportDir is set.
# Mandatory: no
# Range: 1M-1G
# Default:
# ExportFileSize=1G
### Option: ExportType
# List of comma delimited types of real time export - allows to control export entities by their
# type (events, history, trends) individually.
# Valid only if ExportDir is set.
# Mandatory: no
# Default:
# ExportType=events,history,trends
############ ADVANCED PARAMETERS ################
### Option: StartPollers
# Number of pre-forked instances of pollers.
# Mandatory: no
# Range: 0-1000
# Default:
StartPollers=20
### Option: StartIPMIPollers
# Number of pre-forked instances of IPMI pollers.
# The IPMI manager process is automatically started when at least one IPMI poller is started.
# Mandatory: no
# Range: 0-1000
# Default:
# StartIPMIPollers=0
### Option: StartPreprocessors
# Number of pre-started instances of preprocessing workers.
# Mandatory: no
# Range: 1-1000
# Default:
# StartPreprocessors=3
### Option: StartConnectors
# Number of pre-forked instances of connector workers.
# The connector manager process is automatically started when connector worker is started.
# Mandatory: no
# Range: 0-1000
# Default:
# StartConnectors=0
### Option: StartPollersUnreachable
# Number of pre-forked instances of pollers for unreachable hosts (including IPMI and Java).
# At least one poller for unreachable hosts must be running if regular, IPMI or Java pollers
# are started.
# Mandatory: no
# Range: 0-1000
# Default:
StartPollersUnreachable=5
### Option: StartHistoryPollers
# Number of pre-forked instances of history pollers.
# Only required for calculated checks.
# A database connection is required for each history poller instance.
# Mandatory: no
# Range: 0-1000
# Default:
# StartHistoryPollers=5
### Option: StartTrappers
# Number of pre-forked instances of trappers.
# Trappers accept incoming connections from Zabbix sender, active agents and active proxies.
# At least one trapper process must be running to display server availability and view queue
# in the frontend.
# Mandatory: no
# Range: 0-1000
# Default:
# StartTrappers=5
### Option: StartPingers
# Number of pre-forked instances of ICMP pingers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartPingers=1
### Option: StartDiscoverers
# Number of pre-forked instances of discoverers.
# Mandatory: no
# Range: 0-250
# Default:
# StartDiscoverers=1
### Option: StartHTTPPollers
# Number of pre-forked instances of HTTP pollers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartHTTPPollers=1
### Option: StartTimers
# Number of pre-forked instances of timers.
# Timers process maintenance periods.
# Only the first timer process handles host maintenance updates. Problem suppression updates are shared
# between all timers.
# Mandatory: no
# Range: 1-1000
# Default:
# StartTimers=1
### Option: StartEscalators
# Number of pre-forked instances of escalators.
# Mandatory: no
# Range: 1-100
# Default:
# StartEscalators=1
### Option: StartAlerters
# Number of pre-forked instances of alerters.
# Alerters send the notifications created by action operations.
# Mandatory: no
# Range: 1-100
# Default:
# StartAlerters=3
### Option: JavaGateway
# IP address (or hostname) of Zabbix Java gateway.
# Only required if Java pollers are started.
# Mandatory: no
# Default:
# JavaGateway=
### Option: JavaGatewayPort
# Port that Zabbix Java gateway listens on.
# Mandatory: no
# Range: 1024-32767
# Default:
# JavaGatewayPort=10052
### Option: StartJavaPollers
# Number of pre-forked instances of Java pollers.
# Mandatory: no
# Range: 0-1000
# Default:
# StartJavaPollers=0
### Option: StartVMwareCollectors
# Number of pre-forked vmware collector instances.
# Mandatory: no
# Range: 0-250
# Default:
# StartVMwareCollectors=0
### Option: VMwareFrequency
# How often Zabbix will connect to VMware service to obtain a new data.
# Mandatory: no
# Range: 10-86400
# Default:
# VMwareFrequency=60
### Option: VMwarePerfFrequency
# How often Zabbix will connect to VMware service to obtain performance data.
# Mandatory: no
# Range: 10-86400
# Default:
# VMwarePerfFrequency=60
### Option: VMwareCacheSize
# Size of VMware cache, in bytes.
# Shared memory size for storing VMware data.
# Only used if VMware collectors are started.
# Mandatory: no
# Range: 256K-2G
# Default:
# VMwareCacheSize=8M
### Option: VMwareTimeout
# Specifies how many seconds vmware collector waits for response from VMware service.
# Mandatory: no
# Range: 1-300
# Default:
# VMwareTimeout=10
### Option: SNMPTrapperFile
# Temporary file used for passing data from SNMP trap daemon to the server.
# Must be the same as in zabbix_trap_receiver.pl or SNMPTT configuration file.
# Mandatory: no
# Default:
# SNMPTrapperFile=/tmp/zabbix_traps.tmp
SNMPTrapperFile=/var/log/snmptrap/snmptrap.log
### Option: StartSNMPTrapper
# If 1, SNMP trapper process is started.
# Mandatory: no
# Range: 0-1
# Default:
# StartSNMPTrapper=0
### Option: ListenIP
# List of comma delimited IP addresses that the trapper should listen on.
# Trapper will listen on all network interfaces if this parameter is missing.
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
### Option: HousekeepingFrequency
# How often Zabbix will perform housekeeping procedure (in hours).
# Housekeeping is removing outdated information from the database.
# To prevent Housekeeper from being overloaded, no more than 4 times HousekeepingFrequency
# hours of outdated information are deleted in one housekeeping cycle, for each item.
# To lower load on server startup housekeeping is postponed for 30 minutes after server start.
# With HousekeepingFrequency=0 the housekeeper can be only executed using the runtime control option.
# In this case the period of outdated information deleted in one housekeeping cycle is 4 times the
# period since the last housekeeping cycle, but not less than 4 hours and not greater than 4 days.
# Mandatory: no
# Range: 0-24
# Default:
# HousekeepingFrequency=1
### Option: MaxHousekeeperDelete
# The table "housekeeper" contains "tasks" for housekeeping procedure in the format:
# [housekeeperid], [tablename], [field], [value].
# No more than 'MaxHousekeeperDelete' rows (corresponding to [tablename], [field], [value])
# will be deleted per one task in one housekeeping cycle.
# If set to 0 then no limit is used at all. In this case you must know what you are doing!
# Mandatory: no
# Range: 0-1000000
# Default:
# MaxHousekeeperDelete=5000
### Option: CacheSize
# Size of configuration cache, in bytes.
# Shared memory size for storing host, item and trigger data.
# Mandatory: no
# Range: 128K-64G
# Default:
CacheSize=1G
### Option: CacheUpdateFrequency
# How often Zabbix will perform update of configuration cache, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# CacheUpdateFrequency=10
### Option: StartDBSyncers
# Number of pre-forked instances of DB Syncers.
# Mandatory: no
# Range: 1-100
# Default:
# StartDBSyncers=4
### Option: HistoryCacheSize
# Size of history cache, in bytes.
# Shared memory size for storing history data.
# Mandatory: no
# Range: 128K-2G
# Default:
# HistoryCacheSize=16M
### Option: HistoryIndexCacheSize
# Size of history index cache, in bytes.
# Shared memory size for indexing history cache.
# Mandatory: no
# Range: 128K-2G
# Default:
HistoryIndexCacheSize=32M
### Option: TrendCacheSize
# Size of trend write cache, in bytes.
# Shared memory size for storing trends data.
# Mandatory: no
# Range: 128K-2G
# Default:
TrendCacheSize=16M
### Option: TrendFunctionCacheSize
# Size of trend function cache, in bytes.
# Shared memory size for caching calculated trend function data.
# Mandatory: no
# Range: 128K-2G
# Default:
# TrendFunctionCacheSize=4M
### Option: ValueCacheSize
# Size of history value cache, in bytes.
# Shared memory size for caching item history data requests.
# Setting to 0 disables value cache.
# Mandatory: no
# Range: 0,128K-64G
# Default:
# ValueCacheSize=8M
### Option: Timeout
# Specifies how long we wait for agent, SNMP device or external check (in seconds).
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
Timeout=4
### Option: TrapperTimeout
# Specifies how many seconds trapper may spend processing new data.
# Mandatory: no
# Range: 1-300
# Default:
# TrapperTimeout=300
### Option: UnreachablePeriod
# After how many seconds of unreachability treat a host as unavailable.
# Mandatory: no
# Range: 1-3600
# Default:
# UnreachablePeriod=45
### Option: UnavailableDelay
# How often host is checked for availability during the unavailability period, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# UnavailableDelay=60
### Option: UnreachableDelay
# How often host is checked for availability during the unreachability period, in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# UnreachableDelay=15
### Option: AlertScriptsPath
# Full path to location of custom alert scripts.
# Default depends on compilation options.
# To see the default path run command "zabbix_server --help".
# Mandatory: no
# Default:
# AlertScriptsPath=/usr/lib/zabbix/alertscripts
### Option: ExternalScripts
# Full path to location of external scripts.
# Mandatory: no
# Default:
# ExternalScripts=/usr/lib/zabbix/externalscripts
### Option: FpingLocation
# Location of fping.
# Make sure that fping binary has root ownership and SUID flag set.
# Mandatory: no
# Default:
# FpingLocation=/usr/sbin/fping
FpingLocation=/usr/bin/fping
### Option: Fping6Location
# Location of fping6.
# Make sure that fping6 binary has root ownership and SUID flag set.
# Make empty if your fping utility is capable to process IPv6 addresses.
# Mandatory: no
# Default:
# Fping6Location=/usr/sbin/fping6
Fping6Location=/usr/bin/fping6
### Option: SSHKeyLocation
# Location of public and private keys for SSH checks and actions.
# Mandatory: no
# Default:
# SSHKeyLocation=
### Option: LogSlowQueries
# How long a database query may take before being logged (in milliseconds).
# Only works if DebugLevel set to 3, 4 or 5.
# 0 - don't log slow queries.
# Mandatory: no
# Range: 1-3600000
# Default:
# LogSlowQueries=0
LogSlowQueries=3000
### Option: TmpDir
# Temporary directory.
# Mandatory: no
# Default:
# TmpDir=/tmp
### Option: StartProxyPollers
# Number of pre-forked instances of pollers for passive proxies.
# Mandatory: no
# Range: 0-250
# Default:
# StartProxyPollers=1
### Option: ProxyConfigFrequency
# How often Zabbix Server sends configuration data to a Zabbix Proxy in seconds.
# This parameter is used only for proxies in the passive mode.
# Mandatory: no
# Range: 1-3600*24*7
# Default:
# ProxyConfigFrequency=10
### Option: ProxyDataFrequency
# How often Zabbix Server requests history data from a Zabbix Proxy in seconds.
# Mandatory: no
# Range: 1-3600
# Default:
# ProxyDataFrequency=1
### Option: StartLLDProcessors
# Number of pre-forked instances of low level discovery processors.
# Mandatory: no
# Range: 1-100
# Default:
# StartLLDProcessors=2
### Option: AllowRoot
# Allow the server to run as 'root'. If disabled and the server is started by 'root', the server
# will try to switch to the user specified by the User configuration option instead.
# Has no effect if started under a regular user.
# 0 - do not allow
# 1 - allow
# Mandatory: no
# Default:
# AllowRoot=0
### Option: User
# Drop privileges to a specific, existing user on the system.
# Only has effect if run as 'root' and AllowRoot is disabled.
# Mandatory: no
# Default:
# User=zabbix
### Option: Include
# You may include individual files or all files in a directory in the configuration file.
# Installing Zabbix will create include directory in /usr/local/etc, unless modified during the compile time.
# Mandatory: no
# Default:
# Include=
# Include=/usr/local/etc/zabbix_server.general.conf
# Include=/usr/local/etc/zabbix_server.conf.d/
# Include=/usr/local/etc/zabbix_server.conf.d/*.conf
### Option: SSLCertLocation
# Location of SSL client certificates.
# This parameter is used only in web monitoring.
# Mandatory: no
# Default:
# SSLCertLocation=${datadir}/zabbix/ssl/certs
### Option: SSLKeyLocation
# Location of private keys for SSL client certificates.
# Mandatory: no
# Default:
# SSLKeyLocation=${datadir}/zabbix/ssl/keys
### Option: SSLCALocation
# Override the location of certificate authority (CA) files for SSL server certificate verification.
# If not set, system-wide directory will be used.
# This parameter is used in web monitoring, SMTP authentication, HTTP agent items and for communication with Vault.
# Mandatory: no
# Default:
# SSLCALocation=
### Option: StatsAllowedIP
# List of comma delimited IP addresses, optionally in CIDR notation, or DNS names of external Zabbix instances.
# Stats request will be accepted only from the addresses listed here. If this parameter is not set no stats requests
# will be accepted.
# If IPv6 support is enabled then '127.0.0.1', '::127.0.0.1', '::ffff:127.0.0.1' are treated equally
# and '::/0' will allow any IPv4 or IPv6 address.
# '0.0.0.0/0' can be used to allow any IPv4 address.
# Example: StatsAllowedIP=127.0.0.1,192.168.1.0/24,::1,2001:db8::/32,zabbix.example.com
# Mandatory: no
# Default:
# StatsAllowedIP=
####### LOADABLE MODULES #######
### Option: LoadModulePath
# Full path to location of server modules.
# Mandatory: no
# Default:
# LoadModulePath=${libdir}/modules
# Module to load at server startup. Modules are used to extend functionality of the server.
# Formats:
# LoadModule=<module.so>
# LoadModule=<path/module.so>
# LoadModule=</abs_path/module.so>
# Either the module must be located in directory specified by LoadModulePath or the path must precede the module name.
# If the preceding path is absolute (starts with '/') then LoadModulePath is ignored.
# It is allowed to include multiple LoadModule parameters.
# Mandatory: no
# Default:
# LoadModule=
####### TLS-RELATED PARAMETERS #######
### Option: TLSCAFile
# Full pathname of a file containing the top-level CA(s) certificates for
# peer certificate verification.
# Mandatory: no
# Default:
# TLSCAFile=
### Option: TLSCRLFile
# Full pathname of a file containing revoked certificates.
# Mandatory: no
# Default:
# TLSCRLFile=
### Option: TLSCertFile
# Full pathname of a file containing the server certificate or certificate chain.
# Mandatory: no
# Default:
# TLSCertFile=
### Option: TLSKeyFile
# Full pathname of a file containing the server private key.
# Mandatory: no
# Default:
# TLSKeyFile=
####### For advanced users - TLS ciphersuite selection criteria #######
### Option: TLSCipherCert13
# Cipher string for OpenSSL 1.1.1 or newer in TLS 1.3.
# Override the default ciphersuite selection criteria for certificate-based encryption.
# Mandatory: no
# Default:
# TLSCipherCert13=
# GnuTLS priority string or OpenSSL (TLS 1.2) cipher string.
# Example for GnuTLS:
# NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
# Example for OpenSSL:
# EECDH+aRSA+AES128:RSA+aRSA+AES128
# Mandatory: no
# Default:
# TLSCipherCert=
### Option: TLSCipherPSK13
# Override the default ciphersuite selection criteria for PSK-based encryption.
# Example:
# TLS_CHACHA20_POLY1305_SHA256:TLS_AES_128_GCM_SHA25 6
# Mandatory: no
# Default:
# TLSCipherPSK13=
# NONE:+VERS-TLS1.2:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL
# kECDHEPSK+AES128:kPSK+AES128
# Mandatory: no
# Default:
# TLSCipherPSK=
### Option: TLSCipherAll13
# Override the default ciphersuite selection criteria for certificate- and PSK-based encryption.
# Example:
# TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA25 6:TLS_AES_128_GCM_SHA256
# Mandatory: no
# Default:
# TLSCipherAll13=
# NONE:+VERS-TLS1.2:+ECDHE-RSA:+RSA:+ECDHE-PSK:+PSK:+AES-128-GCM:+AES-128-CBC:+AEAD:+SHA256:+SHA1:+CURVE-ALL:+COMP-NULL:+SIGN-ALL:+CTYPE-X.509
# EECDH+aRSA+AES128:RSA+aRSA+AES128:kECDHEPSK+AES128 :kPSK+AES128
# Mandatory: no
# Default:
# TLSCipherAll=
### Option: DBTLSConnect
# Setting this option enforces to use TLS connection to database.
# required - connect using TLS
# verify_ca - connect using TLS and verify certificate
# verify_full - connect using TLS, verify certificate and verify that database identity specified by DBHost
# matches its certificate
# On MySQL starting from 5.7.11 and PostgreSQL following values are supported: "required", "verify_ca" and
# "verify_full".
# On MariaDB starting from version 10.2.6 "required" and "verify_full" values are supported.
# Default is not to set any option and behavior depends on database configuration
# Mandatory: no
# Default:
# DBTLSConnect=
### Option: DBTLSCAFile
# Full pathname of a file containing the top-level CA(s) certificates for database certificate verification.
# Supported only for MySQL and PostgreSQL
# Mandatory: no
# (yes, if DBTLSConnect set to one of: verify_ca, verify_full)
# Default:
# DBTLSCAFile=
### Option: DBTLSCertFile
# Full pathname of file containing Zabbix server certificate for authenticating to database.
# Mandatory: no
# Default:
# DBTLSCertFile=
### Option: DBTLSKeyFile
# Full pathname of file containing the private key for authenticating to database.
# Mandatory: no
# Default:
# DBTLSKeyFile=
### Option: DBTLSCipher
# The list of encryption ciphers that Zabbix server permits for TLS protocols up through TLSv1.2
# Mandatory no
# Default:
# DBTLSCipher=
### Option: DBTLSCipher13
# The list of encryption ciphersuites that Zabbix server permits for TLSv1.3 protocol
# Supported only for MySQL, starting from version 8.0.16
# Mandatory no
# Default:
# DBTLSCipher13=
### Option: Vault
# Specifies vault:
# HashiCorp - HashiCorp KV Secrets Engine - Version 2
# CyberArk - CyberArk Central Credential Provider
# Mandatory: no
# Default:
# Vault=HashiCorp
### Option: VaultToken
# Vault authentication token that should have been generated exclusively for Zabbix server with read only permission
# to paths specified in Vault macros and read only permission to path specified in optional VaultDBPath
# configuration parameter.
# It is an error if VaultToken and VAULT_TOKEN environment variable are defined at the same time.
# Mandatory: no
# (yes, if Vault is explicitly set to HashiCorp)
# Default:
# VaultToken=
### Option: VaultURL
# Vault server HTTP[S] URL. System-wide CA certificates directory will be used if SSLCALocation is not specified.
# Mandatory: no
# Default:
# VaultURL=https://127.0.0.1:8200
### Option: VaultDBPath
# Vault path or query depending on the Vault from where credentials for database will be retrieved by keys.
# Keys used for HashiCorp are 'password' and 'username'.
# Example path:
# secret/zabbix/database
# Keys used for CyberArk are 'Content' and 'UserName'.
# Example query:
# AppID=zabbix_server&Query=Safe=passwordSafe;Object =zabbix_server_database
# This option can only be used if DBUser and DBPassword are not specified.
# Mandatory: no
# Default:
# VaultDBPath=
### Option: VaultTLSCertFile
# Name of the SSL certificate file used for client authentication. The certificate file must be in PEM1 format.
# If the certificate file contains also the private key, leave the SSL key file field empty. The directory
# containing this file is specified by configuration parameter SSLCertLocation.
# Mandatory: no
# Default:
# VaultTLSCertFile=
### Option: VaultTLSKeyFile
# Name of the SSL private key file used for client authentication. The private key file must be in PEM1 format.
# The directory containing this file is specified by configuration parameter SSLKeyLocation.
# Mandatory: no
# Default:
# VaultTLSKeyFile=
### Option: StartReportWriters
# Number of pre-forked report writer instances.
# Mandatory: no
# Range: 0-100
# Default:
# StartReportWriters=0
### Option: WebServiceURL
# URL to Zabbix web service, used to perform web related tasks.
# Example: http://localhost:10053/report
# Mandatory: no
# Default:
# WebServiceURL=
### Option: ServiceManagerSyncFrequency
# How often Zabbix will synchronize configuration of a service manager (in seconds).
# Mandatory: no
# Range: 1-3600
# Default:
# ServiceManagerSyncFrequency=60
### Option: ProblemHousekeepingFrequency
# How often Zabbix will delete problems for deleted triggers (in seconds).
# Mandatory: no
# Range: 1-3600
# Default:
# ProblemHousekeepingFrequency=60
## Option: StartODBCPollers
# Number of pre-forked ODBC poller instances.
# Mandatory: no
# Range: 0-1000
# Default:
# StartODBCPollers=1
####### For advanced users - TCP-related fine-tuning parameters #######
## Option: ListenBacklog
# The maximum number of pending connections in the queue. This parameter is passed to
# listen() function as argument 'backlog' (see "man listen").
# Mandatory: no
# Range: 0 - INT_MAX (depends on system, too large values may be silently truncated to implementation-specified maximum)
# Default: SOMAXCONN (hard-coded constant, depends on system)
# ListenBacklog=
####### High availability cluster parameters #######
## Option: HANodeName
# The high availability cluster node name.
# When empty, server is working in standalone mode; a node with empty name is registered with address for the frontend to connect to.
# Mandatory: no
# Default:
# HANodeName=
## Option: NodeAddress
# IP or hostname with optional port to specify how frontend should connect to the server.
# Format: <address>[:<port>]
# If IP or hostname is not set, then ListenIP value will be used. In case ListenIP is not set, localhost will be used.
# If port is not set, then ListenPort value will be used. In case ListenPort is not set, 10051 will be used.
# This option can be overridden by address specified in frontend configuration.
# Mandatory: no
# Default:
# NodeAddress=localhost:10051
# Mandatory: no
# Range: 1024-32767
# Default:
# ListenPort=10051
# Mandatory: no
# Default:
# SourceIP=
### Option: LogType
# system - syslog
# Mandatory: no
# Default:
# LogType=file
### Option: LogFile
# Default:
# LogFile=
# Mandatory: no
# Range: 0-1024
# Default:
# LogFileSize=1
LogFileSize=0
# 3 - warnings
# Mandatory: no
# Range: 0-5
# Default:
# DebugLevel=3
### Option: PidFile
# Name of PID file.
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# SocketDir=/tmp
### Option: DBHost
# Mandatory: no
# Default:
DBHost=10.****
### Option: DBName
# Database name.
# empty string.
# Mandatory: yes
# Default:
# DBName=
DBName=zabbix
# Mandatory: no
# Default:
# DBSchema=
### Option: DBUser
# Database user.
# Mandatory: no
# Default:
# DBUser=
DBUser=zabbix
# Mandatory: no
# Default:
DBPassword=*******
# Mandatory: no
# Default:
# DBSocket=
### Option: DBPort
# Mandatory: no
# Range: 1024-65535
# Default:
DBPort=5432
# 0 - do not allow
# 1 - allow
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# 0 - disable
# 1 - enable
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# ExportDir=
# Mandatory: no
# Range: 1M-1G
# Default:
# ExportFileSize=1G
# Mandatory: no
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
StartPollers=20
# Mandatory: no
# Range: 0-1000
# Default:
# Mandatory: no
# Range: 1-1000
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
# StartConnectors=0
# are started.
# Mandatory: no
# Range: 0-1000
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
# in the frontend.
# Mandatory: no
# Range: 0-1000
# Default:
# StartTrappers=5
# Mandatory: no
# Range: 0-1000
# Default:
# StartPingers=1
# Mandatory: no
# Range: 0-250
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
# Mandatory: no
# Range: 1-1000
# Default:
# StartTimers=1
# Mandatory: no
# Range: 1-100
# Default:
# StartEscalators=1
# Mandatory: no
# Range: 1-100
# Default:
# StartAlerters=3
# Mandatory: no
# Default:
# JavaGateway=
# Mandatory: no
# Range: 1024-32767
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
# Mandatory: no
# Range: 0-250
# Default:
# Mandatory: no
# Range: 10-86400
# Default:
# Mandatory: no
# Range: 10-86400
# Default:
# Mandatory: no
# Range: 256K-2G
# Default:
# Mandatory: no
# Range: 1-300
# Default:
# VMwareTimeout=10
# Mandatory: no
# Default:
# Mandatory: no
# Range: 0-1
# Default:
# Mandatory: no
# Default:
# ListenIP=0.0.0.0
# Mandatory: no
# Range: 0-24
# Default:
# Mandatory: no
# Range: 0-1000000
# Default:
# Mandatory: no
# Range: 128K-64G
# Default:
CacheSize=1G
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 1-100
# Default:
# StartDBSyncers=4
# Mandatory: no
# Range: 128K-2G
# Default:
# Mandatory: no
# Range: 128K-2G
# Default:
# Mandatory: no
# Range: 128K-2G
# Default:
TrendCacheSize=16M
# Mandatory: no
# Range: 128K-2G
# Default:
# Mandatory: no
# Range: 0,128K-64G
# Default:
# ValueCacheSize=8M
### Option: Timeout
# Mandatory: no
# Range: 1-30
# Default:
# Timeout=3
Timeout=4
# Mandatory: no
# Range: 1-300
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# SSHKeyLocation=
# Mandatory: no
# Range: 1-3600000
# Default:
# LogSlowQueries=0
LogSlowQueries=3000
### Option: TmpDir
# Mandatory: no
# Default:
# TmpDir=/tmp
# Mandatory: no
# Range: 0-250
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 1-100
# Default:
# 0 - do not allow
# 1 - allow
# Mandatory: no
# Default:
# AllowRoot=0
### Option: User
# Mandatory: no
# Default:
# User=zabbix
### Option: Include
# Mandatory: no
# Default:
# Include=
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# Mandatory: no
# Default:
# SSLCALocation=
# will be accepted.
# Mandatory: no
# Default:
# StatsAllowedIP=
# Mandatory: no
# Default:
# Formats:
# Mandatory: no
# Default:
# LoadModule=
# Mandatory: no
# Default:
# TLSCAFile=
# Mandatory: no
# Default:
# TLSCRLFile=
# Mandatory: no
# Default:
# TLSCertFile=
# Mandatory: no
# Default:
# TLSKeyFile=
# Mandatory: no
# Default:
# TLSCipherCert13=
# Mandatory: no
# Default:
# TLSCipherCert=
# Example:
# Mandatory: no
# Default:
# TLSCipherPSK13=
# Mandatory: no
# Default:
# TLSCipherPSK=
# Example:
# Mandatory: no
# Default:
# TLSCipherAll13=
# Mandatory: no
# Default:
# TLSCipherAll=
# "verify_full".
# Mandatory: no
# Default:
# DBTLSConnect=
# Mandatory: no
# Default:
# DBTLSCAFile=
# Mandatory: no
# Default:
# DBTLSCertFile=
# Mandatory: no
# Default:
# DBTLSKeyFile=
# Mandatory no
# Default:
# DBTLSCipher=
# Mandatory no
# Default:
# DBTLSCipher13=
### Option: Vault
# Specifies vault:
# Mandatory: no
# Default:
# Vault=HashiCorp
# Mandatory: no
# Default:
# VaultToken=
# Mandatory: no
# Default:
# Example path:
# Example query:
# Mandatory: no
# Default:
# VaultDBPath=
# Mandatory: no
# Default:
# VaultTLSCertFile=
# Mandatory: no
# Default:
# VaultTLSKeyFile=
# Mandatory: no
# Range: 0-100
# Default:
# Mandatory: no
# Default:
# WebServiceURL=
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 1-3600
# Default:
# Mandatory: no
# Range: 0-1000
# Default:
# Mandatory: no
# ListenBacklog=
# Mandatory: no
# Default:
# HANodeName=
# Mandatory: no
# Default:
